Question about Hitachi 500GB External USB 2.0 Hard Drive
Hitachi External hard drive 500GB doesnt turn on
My external hitachi hard drive doesn't turn on..
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Driver windows xp
I have had the same problem with Vista and win 7 with USB connection. Using it with XP its perfect. what operating system are you using?
Jan 20, 2014 | Hitachi 500GB External USB 2.0 Hard Drive
CAN I RESOLDER THE USB CONNECTION ON MY HITACHI EXTERNAL HARDDRIVE?
You can, though I would not suggest it unless it is out of warranty. Take advantage of whatever warrant is supplied by Hitachi.
Nov 03, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Hitachi 500gb external usb 2.0 hard drive not detected
if it is clicking or not whirring it is broken if not go to control panel,system,disk management the see if you see it there and format it to NTFS hope this helps =]!
Mar 03, 2012 | Hitachi 500GB External USB 2.0 Hard Drive
My hitachi external hard drive needs formatting how do i format
Just plug it into your computer, go into your desktop and click on My Computer, find the external drive that you plugged in, right click on it and scroll down to format, please keep in mind that all data will be lost once you start formatting drive. Let me know if this solved the problem and good luck..
Sep 09, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
Hitachi 500gb external hard disk is unable to detech
Have you made sure you have good connections between the computer and hard drive? Sometimes connectors are not pushed in all the way. You might try another cable, or check the drive on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 06, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Hitachi External Hard Drive 500 g where do i get the driver for it ?
This is what I get from Hitachi about the USB drives:
The External USB Storage and Portable USB Storage products do not need additional drivers to function in WinXP/2000/Vista, or the Mac system 9.2.2 or OSX. These operating systems already include the drivers needed for USB storage devices.
Looks like you don't need a driver. This is what I expected.
Feb 02, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Power supply
Hi backerman,
Hitachi has several hard drive models with a 500GB capacity. To ensure you choose the correct power supply, I suggest you contact Hitachi support toll free at (888) 426 5214.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 13, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Hitachi 500GB External USB 2.0 Hard Drive Logo
248 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
