Question about Logitech Harmony 520 LCD Remote Control
Locked in safe mode
Remote is locked in safe mode How to exit the safe mode?
Hi. All you need to do to solve this problem is update the firmware.
1. Connect the remote and launch the software
2. Click 'Downloads' at the top
3. Click 'Firmware'
4. Update the remote
Hope that helps.
Posted on Apr 08, 2010
I am not able to use the hand held lock/unlock now. The driver door lock tries to work, but it won't. If I push the lock down manually, it will lock all locks. What could be wrong?
Note:
Entering the programming mode cancels all learned keyless remotes, so none of the
previously programmed remotes will work. You must reprogram all of the keyless
remotes once you are in the programming mode. You must complete each step within 5 seconds of the previous step to keep the
system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed
remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used
in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door
locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make
sure door locks cycle after you push each remote button to confirm system has
accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
Mar 07, 2010 | 2002 Honda CR-V
I own 2008 passat, I want to know if there is a way to lock the doors so it can't be opened from the inside
as far as i no the only way is to activate the central locking via the remote,which puts the locks into safe mode and the doors cannot be opened from the inside or outside.the system was not designed to go into safe mode when manually locking with the locking button inside the vehicle,this is a safety measurein the event of an emergency incase you or your passengers need to exit the vehicle..i dont think it can be done..sorry.
Oct 18, 2009 | 2000 Volkswagen Passat 4Motion
My Logitech Remote 550 is Locked in the Safe Mode. How do I get it our of Safe Mode.
Doing a firmware upgrade is the BEST way to recover from Safe Mode. A remote may go into safe mode itself for a variety of reasons.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Hope this helps
Sep 24, 2009 | Logitech Harmony 550 Remote Control
Harmony 550 in safe mode
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
Aug 29, 2009 | Logitech Harmony 550 Remote Control
Locked in safe mode
All you need to do is update the firmware on the remot ena dit will come out of safe mode.
3. Click 'Firmware'
Apr 15, 2009 | Logitech Harmony 520 LCD Remote Control
How to program the keyless entry for my 1996 Acura TL.
Hi, Stacie,
here's the instructions for a 97 TL - I hope they're the same.
Note:
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode.
You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
(An unprogrammed remote can be used for this step.)
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
Make sure the power door locks cycle to confirm you are in programming
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
each remote button to confirm system has accepted the remote.
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Hope this helps :)
John
Mar 26, 2009 | 1998 Acura TL
Keyless remote
Note:
all of the keyless remotes once you are in the programming mode. You must complete each step within 4 seconds of the previous step to keep
used in step 2
mode.
10. Test remote(s)
Dec 24, 2008 | 1998 Acura TL
Locked in safe mode
Hi. Here is how to get your remote out of safe mode.
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this helps.
Jun 30, 2008 | Logitech Harmony 670 LCD Remote Control
Logitech Harmony 520 LCD Remote Control Logo
275 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
