Question about Toshiba 42HL196 42 in. LCD HDTV
72'' screen ST7285 TV Won't come on.
Have checked all connections. Have unplugged all & reconnected. Still no service. Has b;ie light on front screen and flashing yellow light on time record. But no picture or sound. New system (less 6 months) but have misplaced instructions. Would appreciate any suggestions. Toshiba 42", yellow light flashes 3 times, won't turn on.
  • 197 Answers
Bad sein pcb
Posted on Jun 07, 2009
The screen display is blank. We unplug it and still nothing.
ok check that you have power connected. most have a power indication light. also check the computer is on once you have reconnected. might be the screen has died if you get nothing borrow a display or connect to tv and see if you can get signal from pc
Dec 27, 2017 | The Computers & Internet
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
We had a power outage today and our tv won't turn on - there is a green flashing light on the front panel and that is it.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 18, 2010 | Televison & Video
I have a kds-55a2000 and it will not turn on. A green light in the front blinks.
Jul 24, 2010 | Sony KDS55A2000 55" HDTV
The screen is completly redand i have 5 blinks in front
Jul 23, 2010 | Sony KP-51WS500 51" Rear Projection...
What does IE error code on LG front loader mean
"IE" is an error code that indicates a water inlet problem on an LG washing machine. This code will appear if the washer is not filled to the correct level within eight minutes after switching it on. Possible causes for the IE code include partially closed taps, improperly attached inlet hoses or clogged inlet hose filters.
Jun 21, 2010 | LG WM-2277HW Front Load Washer
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Problem
Going back some time ago, I believe that in this model of set, if there is a power supply failure, the sleep timer will show as activated.
I suggest calling the JVC service rep to find out details for this. I believe the power supply will have to be changed. Also, the tech will check the set to find the cause and service it as necessary.
Jerry G.
Oct 31, 2007 | JVC AV-27D302 27" TV
Toshiba 42HL196 42 in. LCD HDTV Logo
280 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
