Question about Samsung Televison & Video
Samsung dlp hl-6165w i replaced the lamp and color wheel still doesnt work its only 3yrs old
Samsung dlphl-6165w i replaced the lamp and color wheel still doesnt work
  • John Snow
    John Snow May 11, 2010
    What have you done to test the color wheel? Is it noisy or not spinning?
SOURCE: How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Posted on Aug 02, 2008
electronick
  • 505 Answers
SOURCE: Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Posted on Jan 08, 2009
  • 1039 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
  • 336 Answers
SOURCE: Replaced lamp. TV does not respond
Hi, do you hear clicking or like a start up sound? if you do it could be an issue with the ballast,that's the board that powers the lamp.Here's how to replace it: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Does your TV make a "whining, whirling, clicking, or humming noise?" If the TV have the infamous blinking lights problem and you're replaced your lamp without success, it's most likely a problem with your color wheel. The Samsung BP96-00674A color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years. Here's how to replace it:http://guides.fixyourdlp.com/samsung/bp96-01579a.php Also make sure door cover is properly shut and also reset lamp timer by unplugging tv wait 5 min and plug it back again.God bless you!
Posted on Sep 30, 2009
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Jun 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-R5056W 56" TV Problem
How old is this TV?
I think its time to replace Lamp.
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
