is there any other way to reset my imate JAQ .... its internal function of factory reset is not working plzz tel me some way to format i-mate JAQ i-mate JAQ WinCE version:- window mobile 5.1.422 AKU 3.2.0 i must to restart my jaq3
i-Mate JAQ3 soft reset Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when the device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it. Any programs you installed, data you entered, and settings you customized on the device will be lost. Only Windows Mobile software and other preinstalled programs will remain.
To perform a soft reset
Remove the battery cover and using the stylus, press on the small button to the left of the battery. Otherwise simply remove the battery, wait a few seconds and then insert the battery again. To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device. 2. Hold down the Send button, End button and Camera button. 3. Do not release Send, End and Camera, press the Power button. 4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard reset
Hard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear 2. On the System tab, select the Master Clear (!) icon 3. Proceed to enter the confirmation code: 1234 and push reset button, system will auto reboot to complete the operation.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
have been using my Imate jama for a year now . One day I switched off as it was hanging . When I...
(More)
have been using my Imate jama for a year now . One day I switched off as it was hanging . When I tried switching on , the window's is not activating , Pls let me know what to do?
(More)
