Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Barrell doesnt spin
Barrell does not spin water syphons and motor runs
  • 30 Answers
Check the drain hose if to low to ground if so raise hose up to even with the tub top or two thirds up on machine. Some washers don't spin until water is drain out first then the pressure switch turns the timer to spin. Hope this may help.
Posted on Jun 02, 2009
My Samsung WF42H5000AW front loader will not change over from rinse to spin. I will continue to go back to rinse over and over for hours. Debris Filter clear and washer drains
Are you sure the load is balanced? or could be a problem with the machines ability to detect out of balance condition. This may involve the motor, (speed sensor) or electronics - or some machines have switches to detect out of balance conditions (weighted pendulums, etc)
Or may be a problem with water level control - for example, when the machine tries to fill to high level for rinsing, it starts to syphon empty, and all the water runs out - then it fills again, syphons and the cycle continues. Syphoning empty is common, and is caused when the end of the drain tube is LOWER than the water level in the machine - or in your case is at a critical point when the machine goes into rinse. Check the installation instructions re waste hose positioning. Check the waste hose hasn't become sealed air tight into the waste pipe with slime, etc too!
Feb 02, 2018 | Samsung Washing Machines
Creda water level sensor
You have a blockage in the syphon assy or a split syphon pipe
Sep 08, 2012 | Creda W100FW Front Load Washer
Drum will not spin on spin cycle Belt ok not slack water syphoning pump ok and working would it be the brushes in the motor compartment are worn
More than likely, it will be the brushes that need to be replaced,
you will need to remove the motor to do this.
Sep 23, 2010 | Bosch Washing Machines
Neff washing machine - barrel doesnt spin
I would recommend it. Otherwise they will have to run new wires from control module all the way down to the motor. I would get my money back since they didn't replace the right piece.
Jun 23, 2009 | Neff W4380X1 Front Load Washer
Top load barrell will not spin on rinsr nor spin cycle
if it is syphoning......pull the drain house out of the stand pipe it is in tooooooo far. once it is too far down it does not have an air gap anymore which causes it to fill and drain and never reach maximum water level. the hose should only be in the stand pipe 6 inches. when you pull the hose out of the wall and you hear it go glub glub glub and water exits the hose that is a major sign of syphoning. And yes it can be intermitten. Let me know how it goes and if you have any other questions.
Jun 02, 2009 | Whirlpool Washing Machines
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Ammana washer wont agitate
If the motor is on in the agitation part of cycle and its not agitating your transmission spline is either stripped our your trans. is broken.If the motor is not on and its full of water in the agitation cycle make sure it is not syphoning.Please rate this !
Jun 22, 2008 | Amana NAV5800A Top Load Washer
Kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
186 people viewed this question
Dan Webster
Dan Webster
Sal De
