Question about Yamaha Music
Displays code Scn
Yamaha digital piano model p90 worked fine. Then turned it on and got code Scn flashing. Midi works demos work. Metronome works. Keyboard does not work. Maybe Scn stands for Scan. I.E. cannot scan the keyboard.
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
Posted on Jul 06, 2009
Why do keys produce no sound?
Hi Kyle:
Have a look at your manual.
Sometimes you'll find that there will be an "input" setting required.
You might also try google with his link.
https://www.google.ca/#q=Williams+Allegro+88-Key+Digital+Piano
Hope this helps.
Cheers.
Oct 13, 2015 | Williams Allegro 88-Key Digital Piano
The metronome on my P90 won't switch off. Is there a way I can fix this easily?
The P90 uses a rubber membrane switch to turn the metronome on/off it maybe that this has failed. Inside the rubber is a carbon contact that bridges over the PCB. If this gets dusty or worn out then it will not operate. This could be the cause, dismantle and clean and try again.
If not then it is with the electrical circuitry which would be harder to diagnose.
Jan 27, 2015 | Music
I have a Yamaha P-105. It is just over a year old and we have never attempted to transpose anything. Tonight I tried and it won't work. I hold down the DEMO/SONG and METRONOME/RHYTHM button
i would discuss it with the dealer you bought it from. He'll have you go though the commands again just to be sure. At that point he'll ask that it be brrought in for service or will refer you to a service center. If it is over a year old it will be out of warranty, but if you approch him polietly he may try to bend the time period for you.
Dec 03, 2014 | Yamaha P-105 Digital Piano, Black
Hello, I have a Yamaha P90. 4 keys are not responding. all others are ok and give sound. What happened ?
If they are the same note- different octave- it may be a bad solder joint near the main oscillator IC.
If they are the same cluster (adjacent white keys or adjacent black keys) in the octave, it may be a faulty wire connection.
Apr 01, 2012 | Yamaha P90 Digital Piano
My P85 digital piano have not a good trasmission with midi cable USB, in particular when press the sustain pedal trasmit a note to pc. Thanks
It is IMPORTANT to realize that the SUSTAIN is NOT attached to a note, but is an independent MIDI message. Hence it is up to the external MIDI device to associate the sustain with whatever notes are still active.
Feb 27, 2011 | Yamaha P85 88Key Portable Digital Piano
How to open 3 demo pieces of Technics SX-PC10 Digital Piano?
Usually you just select which demo BEFORE starting the demo.
If you are meaning to try to DOWNLOAD via MIDI or other those demo pieces that is USUALLY not possible as the pieces are stored in a ROM which is inaccessible via MIDI or USB.
They OFTEN don''t even send them out on the MIDI port when playing them.
Apr 30, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
I'm in the studio using LogicPro with my MO8 -
In General MIDI, the grand piano is defaulted to MIDI channel 1.
IF you have a device that responds to "General MIDI" format, just send the MIDI data to channel one and you should be fine. Remember that pianos are VELOCITY controlled and usually don't use after touch so you have to generate appropriate velocity for EACH note if you are using an editor.
Jan 07, 2010 | Yamaha Music
I am getting the error message scn on my p120 keyboard and there is no sound from the keyboard.
Just bought a P120 from craigslist. A computer recycle company was selling it as parts for $150. They said it has the SCN error code and the keys don't play. It played the demos only.. Payed $100; took it home, opened it up & found the keyboard plug had detached from the motherboard. Plugged it in & BAM! It works just fine.
Oct 18, 2009 | Music
Music Logo
412 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
