Question about LG X-Note LM50 Notebook
TURN OFF LOCK KEY FOR FN KEYS
HAVE A light on my laptop that has a picture of a lock with a 1 on it my key k when i type it is a 2 and u is a 4 m is a 0 if i hold down the FN key down and type it works but i don't want to type with 1 hand all the time
  • 696 Answers
Thanks for identifying the light, that is the problem, it is the Numberpad lock indicator that tells you the keyboard is in numeric pad configuration.
Switching it back is a simple matter of finding the num lk key or a key with the same picture beside the light. when you find it hold down the Fn key then press the num lk key and it will switch back to the regular mode.
This is a "feature" of most laptops and although rarely useful is apparently liked by enough people that they keep putting it in ;D
Chris
Posted on Jun 02, 2009
  • amrita Nov 11, 2011
    wow! I can't believe I finally stumbled upon this solution for a problem I've been having since several days! thanks
Microsoft excel 7 disable scrool lock fuction
First locate SCROLL LOCK key in keyboard (Normally it in function keys in laptop, and separate on desktop keyboard).
Now press:-
1. SCROLL LOCK Key
or
2. Fn + SCROLL Lock key (if it is colored as the color of Fn key in laptop)
Sep 30, 2014 | Microsoft Excel Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Locked keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
Nov 10, 2012 | Computers & Internet
My grand daughter has some how turned on the FN key so when she is typing numbers come on the screen instead of the letters. How do we stop this ?
The NumLkkey has been pressed andthe letters on the righr hand side on the keyboard has been converted to a number pad.
The NumLk key also doubles up as the ScrLk key, this is located near the F12 function key. Whenyou press this key to turn on the Numlk a LED will light up to indicate that the Number Lock has been pressed, press this key again to turn off the Number Lock and the NumLk LED will switch off and you will be able to type letters again.
Aug 29, 2011 | Fujitsu Computers & Internet
Hi There. Not sure what key i've gone and pressed. The majority of the letters/numbers on my keyboard all work in first hand english but some of the keys where i have an option with a smaller blue number...
You have turned on the numeric keys on your laptop. It is turned off/on by the following.
Press the Num Lock key. If nothing happens, try Shift+Num Lock.
If the text Num Lock is shown in a different color, find the matching-color key, such as Alt or Fn. Then press that key in combination with Num Lock.
You’re successful when the Num Lock light comes on. At that point, the keyboard has switched into numeric keypad mode.
Read more: http://www.dummies.com/how-to/content/the-hidden-numeric-keypad-on-your-laptop.navId-323018.html#ixzz0vfEI4Odm
Aug 04, 2010 | Computers & Internet
Keys are not matching up . When i type certain letters, it displays numbers. Example. press k, and displays 2. Must hold funtion key to get correct letter.
Your number lock is on. Look for a small picture that looks like a calculator on your keyboard keys (possibly on one of the F keys at the top). Press the Fn key plus the key with the calculator pic to turn number lock off.
Jul 19, 2010 | Twinhead Durabook N15RI-2 Notebook PC
My function keys are turned on. how do i turn it
Press the Fn key and the Num Lk key... the reason that your j is a 1 is that the J key is the equivalent of the 1 when the Number lock key is activated. There is a little light up near the power button that shows a lock with a 9 in it... hit the Fn key and the Num Lk key till that light goes out.
Oct 18, 2009 | Dell Inspiron 1501 Notebook
The keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Regards.
Sep 22, 2009 | Computers & Internet
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
LG X-Note LM50 Notebook Logo
1,540 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
