Question about Motorola Mobility H700 Wireless Headset
How to do pairing with the new LG Banter
How do i setup motorola h700 how do i pair the h700 bluetooth to my LG Banter
Basti
  • 1447 Answers
SOURCE: Pairing LG VX8700 with Motorola H700
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset The phone identifies and maintains up to 16 devices which are displayed in a list. To add a new device or pair a headset via bluetooth, turn Bluetooth™ on in both devices.
  1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
  2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
  3. Choose [TURN ON] , press "Select"
  4. Choose [MY DEVICES], press "Select"
  5. Choose [NEW DEVICE], press "Select"
  6. Choose the headset to be paired and press ' Select '
  7. Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
http://www.sonyericsson.com/cws/support/products/pairinginstructions/w300i?cc=us&lc=en
If you are using a different device the just set the Bluetooth to on on it as well
Posted on Apr 22, 2008
SOURCE: I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Posted on Aug 14, 2008
SOURCE: My Motorola H700 Will Not Pair
I have a sony ericsson W580i that I have been connecting with my motorola S9 for a few months. All of a sudden I started noticing the same problem to where it will not connect. After trying everything else, as a last resort I removed the battery and the SIM card, waited a minute and put it back on. WORKED LIKE A CHARM
Hope it helps
Posted on Sep 18, 2008
  • 54 Answers
SOURCE: can not pair with my new phone
sure can
with the boom mic closed Push and hold the call button until the light around turns purple or stays a blue, then open the boom mic the color should stay on now go in to the phone settings and find the bluetooth settings and search for device once it finds it connecct to it, Remember the Passcode is 0000, and then you should be all set up.
Posted on Jun 28, 2009
vanherringto
  • 1738 Answers
SOURCE: how can i pair up lg vx9900 with motorola bluetooth n136
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Posted on Feb 04, 2010
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
0000 does not work as a passcode to pair my H700 to my LG phone. I have also tried 1234 and every other combo. What is wrong
The default code is either 0000 or 00000. That is, four or five zeroes.
You can set a new pairing pass code once you connect it to your phone by changing the pairing code from under the connected devices settings in your bluetooth menu.
Jan 27, 2011 | Motorola Mobility H700 Wireless Headset
My LG phone is asking for a passcode (Motorola H700). What is this?
It is the code need to have it paired to another device (e.g. phone, computer). For your headset it is hardcoded to '0000' (four zeros). The pairing process between any two bluetooth enbabled devices should be done only once. Once paired, all subsequent connectios between them are normally done by turning their bluetooth radio on and bringing them within each other's range.
By the way, if its user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Sep 28, 2010 | Motorola Mobility H700 Wireless Headset
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Pairing with LG VX8100
Here is step by step from the Motorola Web site. Just click on the orange arrow next to your phone. I would elaborate but I am not familiar with the LG. Here
Hope this helps.
Jul 20, 2008 | Motorola Mobility H700 Wireless Headset
For headset pairing
Apr 22, 2008 | Motorola Mobility H700 Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
964 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
