Question about Waring WMK300 Professional Belgian Waffle Maker
Waring Pro Waffle Maker
Same thing happened to me. It just stopped heating up. It makes a clicking noise and the power light lights, but the ready light never comes on. Waring WMK300C Proffesional BelgianWaffle maker power light goes on and I hear what I assume is a relay clicking on but no heat. Nothing visibly wrong when taken apart. Amost new..not a wear and tear problem! Does anybody have a schematic? signed waffle-less in Winnipeg
Had same issue,found a looks like diode on the black wire leading to the heating elements.It is open circuited.Needs replacing.It is not a diode...maybe a voltage circuit protection device.It is crimped into the black wire under the sleeve clamped down near the handle.Going to radio shack to get a idea,replacement.
Posted on Oct 17, 2009
  • 10,865 Answers
Hi there waffleless! sorry to hear of your troubles. since your unit is nearly new, if it is under one year it is under warranty. Do not take it apart your self as this will void the warranty. Instead send it or take it to the nearest waring service center, listed in your owner manual
Posted on Jun 02, 2009
My impala runs great but when i go to leave and stop at a light and shes in drive sitting at the light she makes noise like loss of power or stalling idk i went to aotuzone they checked my alternator its...
When the AC is turned on, a number of things happen: the cooling fan is engaged, the idle speed is increased to account for the additional load of the compressor, and the AC clutch is engaged. My guess is that what you are hearing is the AC Clutch rattling due to a worn input shaft bearing. As soon as it is engaged, the noise goes away. It is possible that something else is going on here, but I would be tempted to focus on the AC compressor as the SOUND portion of your problem. When you say "...she makes noise like loss of power or stalling, I am not sure what you mean. Is it a noise, or is it actually losing power. With no MIL (check engine) light on and if the noise goes away after servicing the compressor, I would say you are fixed up. Good Luck.
Jul 10, 2014 | Cars & Trucks
Startup takes hours, help?
The clicking suggests a power supply issue, a old trick I use in cases like this is a hairdryer, Try to heat (don't melt things) different boards carefully until you get a dramatic reaction, considering the brand which I do not like much less endorse, what is there to lose.
If you pinpoint the issue to one board try to locate that board.
Dec 11, 2012 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I have a wwm200sa waring pro prof belgian waffle maker that will not get hot. The power light will come on but it will not get hot. Why?
HELP WWM200SA IS WAY TO HOT I HAVE IT DOWN TO 1 1/2 STILL ALMOST BURNED CAN SOMEONE HELP ME THANK YOU VICKY
Aug 02, 2011 | Waring Pro WWM200 Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
Waffle plates stop heating
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower.
Apr 09, 2010 | Waring WMK300 Professional Belgian Waffle...
98 oldmobile regency won't start up and check
Well the fact that the traction light came on and blinked off when taking off is a good thing, it just means that your traction control is working properly. When that light comes on it means that one wheel was spinning and that the car adjusted the speed of the drive wheels to compensate. The car not starting needs to be addressed as to whether the car is turning over slowly, clicking, or making no noise at all. The check engine light will remain on until the vehicle is started, so that does not correlate to your problem. If it clicks, or turns over sluggishly, then it just needs a jump start and a test of the battery. If the lights come on, but the car does not turn over al all, then you may need to look at replacing a starter.
Dec 10, 2009 | 1990 Oldsmobile Regency
Turn on heater@makes a humming noise for a few seconds then stops-red light over thermostat control comes on no heat
there is a problem with the heating element on this heater. I would not use it. I dont know the heater in question but if it were a small inexpensive heater, i would replace the entire thing for safety purposes
Dec 05, 2009 | Electrical Supplies
Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Sep 22, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
1,290 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
