Question about Brother MFC-9840CDW Laser Printer
No preview shown after picture is scanned
After scanning a picture, nothing shows to save.
    Sniper:
  • 86 Answers
If you use Brother's own software, you could: * Open it up (by the clock, called "ControlCenter" or "ControlCenter 3") * Right-click on the type of scan intended (i.e. scan to file) and choose configuration * Here are the settings controlling the scanning. If you change to "device button" on top, you'll get the settings controlling the scanning when you use the scan-button on the machine. * Change the settings to i.e. "show target folder" after scanning, depending on your requested settings.
Posted on Jun 02, 2009
How to scan passport photo
How to scan a document or picture using Windows PAINT
Turn your printer/scanner on!
Click START
type PAINT
click PAINT under programs at top
untitled-paint window opens
in top left corner click the little white arrow
click FROM SCANNER OR CAMERA
choose settings you require
click preview (scanner may have to warm up for 20 seconds)
preview appears in window
adjust edges if need be (click/hold/drag)
click SCAN
item appears in Paint
ckick the white arrow again and choose SAVE AS, give it a name and click SAVE (it will automatically save it to PICTURES)
you can now RESIZE or ROTATE the scan
you can also add text to it by clicking the letter A and drawing a box on the scan
If you want to email it, just close Paint, go to PICTURES, right-click on the scan and choose SEND TO then MAIL RECIPIENT
Aug 26, 2011 | HP Officejet 4355 All-In-One InkJet...
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to scan using hp j4580. Booklet only tells how to fax!!!!
  1. Open HP Solution Center with one of the following methods:
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings.
Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Using epson v500 and can't get it to change the document size under image type in professional mode according to manual. scanning old B&W negatives 2 x 2 in size and it cuts off the image most of the time...
I had the same problem and have found my answer. I don't know if it's the technically correct one but it works.
When you open the scan page and it shows you the mode, setting, original document type, destination, adjustments, and then the preview and scan buttons. Under the Preview button you will see a box check marked for thumbnail. Remove the check and then do a preview scan. You should end up with a complete scan showing the slide (if you only scanned one), the open side and the surrounding blackened area too. Click on the picture in the preview and then draw an outline around the part of the picture that you want to use. Do this just like it you were going to do cropping of the photo. Once you have the box around the part you want click on zoom. Your next preview will be the picture that you want. I haven't figured out how to remove the remaining blackened area with out going into a photo edit program but it must be able to be done. Then you can scan to where ever you save them to and have the whole slide. I hope that this gets you at least some what further along.
Mar 12, 2009 | Epson Perfection V500 Flatbed Scanner
I don't know how to save a scanned document onto my computer. I currently have a HP photosmart3110 All-in-one printer fax scanner copier
Hi
All you need to do is use the scanning software provided with the HP device.
Before scanning it will ask you to look at the preview....when you are happy with the preview start the scanning and then it will ask you where to save it....it might also save it automatically....in which case it will be saved in your my pictures folder.
cheers
Nov 06, 2008 | Computers & Internet
I am trying to scan pictures onto my computer using lexmark 2600 series
How to Scan on Imac using the Lexmark 2600:
1. From the Imac Desktop select the Magnifying glass in the upper right corner of the screen.
2. Search for Preview
3. Open Preview App
4. Put item to scan on Lexmark Glass Face down and close the lid.
5. Select File (In Preview from Top tabs on desktop), then Choose 'Import
Image'
6. Lexmark 2600 Series Window opens
7. Change Scan to Folder, Name and Format to your choices
8. Use cursor to highlight area of image to scan in the 2600 Series Window.
9. Hit Scan from the 2600 Series WIndow.
10. Save the file using the File tab in Preview, and choosing Save
Aug 27, 2008 | Office Equipment & Supplies
My scanjet 4370 won't take pictures?
well, the picture may look the same on the preview, but when you actually save it, it will show you the correct picture. Do a preview first, before you give the scan and save command.
May 11, 2008 | Office Equipment & Supplies
Brother MFC-9840CDW Laser Printer Logo
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
