Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
Can not figure out how to take it apart to replace leakey gasket
HI I can not figure out how to get this one handle moen faucet apart to get the gasket. Any ideas?
  • Cameron loker May 11, 2010
    what are you taking apart.  which gasket
  • 297 Answers
There is an allen key in the front of the handle.may be under where the hot and cold indicator is take that off and look to see if there is a hole.if so use an allen key to remove.
Posted on Jul 29, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen kitchen faucet
    Hi Steve-If the faucet is definitely getting water (making sure all the cut-off valves are open along the way), the Moen single handle faucets all use a replaceable cartridge that is available at home supply stores. This cartridge is what regulates the pressure and the temperature of the water coming out of your faucet. This is likely faulty. You'll need to close the supply valves (hot and cold) underneath your sink prior to replacing.
    Apr 01, 2014 | Plumbing
    I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
    I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
    Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    LEAKS. HAVE GASKET KIT. BUT CAN'T GET IT APART!!
    MOEN ARE NOTORIOUSLY difficult to get appart. There is a "Special tool" just for Moen faucets/tubs/showers. It is like an old "Brake drum puller" or "Faucet handle puller". I think about $10 to $12 at Home Depot or Lowes. FYI Moen and Delta both give "FREE PARTS" on "MOST" faucets for many years if not life, if your not in a hurry. Check your original paperwork for warranty. The washer at the end of the valve after being installed for more than a year, usually binds up and gets torn apart when removed. It makes it VERY difficult to remove, even with the "Special tool". They (Moen) give you a plastic wrench like thing that almost never works, with the purchase of a "New valve" DELTA800-345-3358 ..MOEN-800-289-6636
    Aug 22, 2010 | Moen 87555C Trianna Single Handle Pulldown...
    The faucet drips and I cant figure out how to make it quit.
    It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
    Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
    http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
    http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
    http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
    Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
    Leaky moen 2 handle faucet
    if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen 87135c - cant take apart
    On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
    Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Trying to get the handle off a single handle moen kitchen faucet
    Hi adelinette,
    Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
    Good Luck and please rate this response, Phil
    Jan 03, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    674 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
