Question about Maytag MSD2656G Side by Side Refrigerator
Maytag side by side fridge.
The fridge is working fine but the bar spereating the fridge and freezer gets very very hot.  Is this normal?
  • 1 more comment
  • Anonymous Jun 08, 2008
    I have the same problem with the center post getting, and staying hot. I have read where the defrost heating coils are located in that very location. Has anyone tried replacing the control for the defroster? Thanks.
  • mailforjohns Jan 16, 2009
    The divider between the fridge and freezer is too hot to touch what is the problem? Is it a fire hazard?
  • Alan LaCava Apr 30, 2009
    I got a model msd2456ge its getting hot between doors the fan is working also its getting so hot i have burn marks on gasket and inside the panels of doors and my floor is burnt.Alan
My Maytag side by side #MSD2957AE center front between the doors got very very hot. Too hot to touch. Also the top outside of unit and cabinet above unit unusually hot. I was worried and wondered if it could start a fire. I pulled out from wall and found lots of dust naturally. But the fan was not spinning. I moved it with my finger and it took off spinning. Unplugged, vacumed dust as best I could. Replugged and the fan started spinning on it's own. I plan to watch it. Also clean around the fan motor better, even pull it and lube it with some silicone spray. After running for a while center post is warm but not hot. thank you. JOE.
Posted on Aug 22, 2008
  • joemw Dec 24, 2013
    I did check it later. On the next on-cycle the fan did not start on it\'s own. Had to spin it with my finger. Fan was bad, lost it\'s ability to self start. Got a new one from parts man for around $10. That fixed the problem. Parts mad said the fan cools the condenser. If ifan goes out then condenser overheats thus sending hot freon through the coils running along the door. Said its hard on the condenser. He said it boils the \'slime\' fron the bottom of the condenser and that \'slime\' then circulates and can clog coils. Thus ruining the refridgerator for good.
My Maytag side by side is 7 years old. Bar between fridge and freezer just began getting very, very hot also? What can we do to repair? Does the condenser fan motor need to be replaced?
Posted on Jun 06, 2008
The center bar between the freezer and refrigerator is very hot to the touch. Also about halfway down on the freezer size is also very hot. The ice cubes also seem to be smaller
Heat is normal but the freezer may not be clod enough. Check temp in freezer(0 deg F or -18 C. Also check rear wall of freezer for frost . If so you have a defrost problem which will raise the temp in the freezer. Also check that the condenser fan in the rear bottom of the fridge is running and the condenser is clear,
Nov 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag Performa side by side refridgerator. Water is leaking from behind the panel on the freezer side of of the fridge. Through the vents on the back panel there is a heating coil that seems to come on...
Sounds like a stopped up defrost drain is the reason for seeing water in freezer. That heater is part of the defrost system and should normally come one every 8-12 hours depending on your models defrost cycle b
Nov 19, 2017 | Maytag MSD2756G Side by Side Refrigerator
My refrigerator and freezer working fine,but the door jam between freezer and frig gets very hot can anyone tell me why ?
Either the fan which cools the coils and compressor , behind the rear panel behind the refrig , is not working ( or something is caught in the fan blade ) , or , the coils under the refrig need cleaning badly .
Jun 19, 2010 | Whirlpool ED2FHGX Side by Side...
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
New fridge freezer isgetting very hot on both
This heat is normal. The refrigerator you have in your kitchen will have the condenser coils which get very hot on the bottom or back of the frig. A deep freeze has the condenser coils inside the walls of the freezer. Hot temps are normal when it is running.
Try to leave an inch or so of space around it for air flow and that will help.
Apr 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
LG Refrigerator has no cold air for fridge but freezer works fine
Sounds like the freezer fan(FF)is wearing out, This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. This repair costs parts and labor around $300.00
Jul 31, 2009 | LG Refrigerators
Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
448 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
