Question about LG WD-1280FHD Front Load Washer
Is the heater working?
The Water is not hot or extra hot when the machine is on the hot or sanitary cycle. How come?
  • 30 Answers
The mixing valve where the hoses attach to is stuck at the plunger inside of valve.or the magnets burn out.that pulls the plungers in side of valve. If this may be problem, replace valve. This is called a mixing valve.
Posted on Jun 02, 2009
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
Sanitary cycle does not heat up enough
What is the model number of your unit?
Nov 28, 2012 | Washing Machines
LG Steamwasher after wash cycle left dirty marks on clothes.
You may have some detergent residue inside the tub assembly. You should run a tub clean cycle and use some washing machine cleaner. You can get that at any hardware store. If you don't have a tub clean setting, use the sanitary wash cycle without any laundry inside. You must use the hot water setting for this to work. If you haven't done this in a long time, you may have to run this cycle at least once a week for a month to really clean the machine properly.
Jun 23, 2011 | Washing Machines
I have been delivered a Aquiras Extra WMA 40 but I only have a cold pipe but I notice the machine has a hot and cold pipes do I connect to just the cold pipe and will the machine heat the water inside
No, the machine does not have a heater unless it has a sanitizing cycle which heats already hot water even hotter.
For the machine to work as advertised, you'll need hot and cold water connections. However, if you just hookup the cold water and run the machine on its cold-water setting it will wash -- the laundry may not be as clean as you would like in some cases, but the machine will operate properly.
Charlie
Jan 06, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Won't finish cycle
The water may not be getting hot enough in the rinse cycle. Usually it needs to heat to 140 to 160 degrees for rinsing. If the heating element is not working the water will not heat. If your DW has a Sanitary setting it will be calling for the water to be 160 degrees. If you have the option to override the Sanitary settin, try that to see if the rinse cycle will finish with cooler water.
Mar 27, 2010 | Dishwashers
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Not drying
These dishwashers have no heater for drying dishes. It has a fan to circulate warm air. It is very important that your water temp is at least 120 degrees. It is the combination of hot water and air circulating that dries dishes.
Nov 19, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
LG WD-1280FHD Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
