Question about Whirlpool Accubake SF362LXTS Kitchen Range
Scratches on black ceran cooktop
I have some very fine scratches on my black ceran whirlpool cooktop and also some kind of halo on one of the burner. i use the special cleaner that came with the range, can't get rid of the scratches.
SOURCE: Schott Ceran cooktop on Maytag range
Need a cleaner for this stove top. What do you suggest?
Posted on Feb 26, 2008
tzweeb
  • 318 Answers
SOURCE: glass top is scratched no matter what I do. oven doesn't work ri
glass top stoves are not designed to do canning on, sorry. the only thing you can do for the top is that special cleaner as it has a "wax" in it and will help to prevent stains, but not scratches.
remember your top is glass and it will scratch.
your oven can be calibrated to help it to bake better. what you need to do is make sure you have a temperature problem that can be corrected by calibration. try to just set the oven temps up or down 10 or 20 degrees and try to bake the same items. if this helps then you can reset the calibration of the control as per your owners manual, if you dont have one then i can tell you how if you can tell me the brand and model.
Posted on Jan 15, 2009
  • 24 Answers
SOURCE: I have a whirlpool gas range with 4 burners on
Yep! have a qualified repairman do the adjustments. You do not want to go Boom!! This problem is caused by improper air to fuel mixture. The orange flame and blackened pots are prime indicators.
Posted on May 10, 2011
ginko
  • 19396 Answers
SOURCE: I have Whirlpool Schott Ceran
Hi.
F3 E2 is a temperature runaway error. It means that the control board detected that the oven is too hot. If there is no effective overheating the error occurs because the temperature sensor is shorted.
here the explanation from manual:
F3 E2 : Oven too hot, over heating
Solution:
Test and replace oven temperature sensor.
Before replacement the temperature sensor must be tested. A good sensor will read about 1080 Ohms at room temperature. If the sensor is shorted will only read a couple of Ohms or zero.
If the sensor is good the problem can be the control board, wiring to temperature sensor, or in sporadic cases an heating element that stays always on because of a wiring contact. The last case is quite uncommon.
The most common fault is a defective temperature sensor. The sensor is a probe located inside the oven cavity. The sensor is attached to a two wires connector and held by one or two screws. Disconnect power. Remove the sensor. Undo connector and read Ohms at connector. If there is low impedance replace the probe.
Here a tip explaining how to find parts and diagrams for most aplliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 07, 2011
  • 823 Answers
SOURCE: How can I clean the black, 5 burner gas cooktop. It is a Whirlpool product
Try purchasing a Mr. Clean eraser sponge and use it to clean your range. I have seen them do miracles.
Posted on Nov 26, 2011
My Schott Ceran cooktop will only work on full heat and will not simmer at all. why?
usually there are 2 elements a smal and a large the small one possibly burnt out .
Apr 20, 2015 | Whirlpool 30" Schott Ceran Surface...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 | Cooktops
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    My soup spilled over on to my whirlpool ceran cooktop and i cant get the stains off. Is there a way to do it?
    Is this a ceramic hob? If it is, you will need a ceramic hob cleaner (john lewis does one) OR Astonish oven/pan cleaner, a non-scratch washing-up sponge and a fair amount of elbow grease. This works for me.
    Oct 05, 2009 | Whirlpool RCS3014 Electric Cooktop
    There are burnt on grease stains on my new ceramic glass kitchenaid cooktop on one burner. I've tried cooktop magic and it did remove some, but not all, stains. A razor was recommended to remove the...
    Use the razor push only in one direction this will remove the stain. Ceran is a very resiliant material and you will not scratch it but if you leave gunk on the burner and repeatedly cook on it the stain will become permanant and you also risk pitting the glass. Pitting is pock marks in the glass that are permanant. Pitting is most commonly produced when starch or sugars are left on a burner but is possible with other spills. Good Luck.
    Jan 07, 2009 | Heating & Cooling
    Ceran stock top chipped and cracked
    most of thoose ceran tops have a five year parts only warrenty read your owners under 2-5 years warrenty if it does call ge cust assistance to see what you can do
    Jan 20, 2008 | GE 30 in. JGP328 Gas Cooktop
    Whirlpool Oven, Ceran stove top
    I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
    Nov 20, 2007 | Cooktops
    Whirlpool Accubake SF362LXTS Kitchen Range Logo
    532 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
