Question about Whirlpool Washing Machines
Top load barrell will not spin on rinsr nor spin cycle
Top loader/ barrell will not spin in rinse cycle nor spin cycle water syphons and motor runs.
  • 530 Answers
If it is syphoning......pull the drain house out of the stand pipe it is in tooooooo far. once it is too far down it does not have an air gap anymore which causes it to fill and drain and never reach maximum water level. the hose should only be in the stand pipe 6 inches. when you pull the hose out of the wall and you hear it go glub glub glub and water exits the hose that is a major sign of syphoning. And yes it can be intermitten. Let me know how it goes and if you have any other questions.
Posted on Jun 02, 2009
How do I get fabric softener to flow into washing machine
jrez's answer is for toploaders... you said you have a drawer, so it's a front loader.
The softener is usually taken up by a syphon. This can be removed from the drawer assembly for cleaning, when they clog they can't syphon.
While the machine is taking water for the last rinse, some of the incoming water is sent via the softener compartment. As softener is thick, without a syphon the softener would just sit in the bottom of the compartment and the fresh water would just skim off the top.
SO: Check the drawer after the final rinse.. if the softener compartment is full to the brim, the syphon is blocked. OR .. if there's just the same amount of softener as when you started the cycle, you have a filling problem instead.
Filling problem can be for two reasons: early machines had one water valve, and a flap which squirted water into the various compartments, operated by a linkage from the timer - this linkage can break, the spring can fall off, all mechanical. Later machines use a separate water valve, and this can fail shut.
Feb 15, 2015 | Washing Machines
Won't drain and showing F 01
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
I don't really have a problem, except that my water bill is eating me alive. Approximately how much water does a full load in my 26912 with one rinse use? And how much water are newer models using on...
Most standard top loading washers have a 35 gallon tub capacity. If you go with a High Efficiency (HE) model washer, which can include the Oasis and Cabrio TOP LOADERS, and the Duet, Elite and Epic FRONT LOADERS, they use about 5 to 7 gallons. High Efficiency washers also do not have a continuous motor in action during agitation or tumble cycles, while most standard top loader have a drive motor that runs throughout the cycle. this can also cut down on the amount of electricity that is used. I hope this helps you.
Feb 17, 2010 | Washing Machines
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Barrell doesnt spin
Check the drain hose if to low to ground if so raise hose up to even with the tub top or two thirds up on machine. Some washers don't spin until water is drain out first then the pressure switch turns the timer to spin. Hope this may help.
Jun 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Jun 09, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
