Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
Trying to connect vga cable to tv get format not supported
When i connect my vga to the tv it says format not supported
  • GenRepairMan
    GenRepairMan May 11, 2010
    What kind of TV? HD or Standard?
    What type of connectors are on either side of the cable?
    What brand of video card is in your desktop?
    Did you install your video card's driver and application software?
Adjusted screen resolution to a compatable one for the lcd tv
Posted on Jun 03, 2009
Does the Sony VGN SF790 support hdmi cables? I would like to connect to my Sony Bravia TV
Hi.
No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.
Regards.
Aug 13, 2011 | Sony VAIO VGN-FS790 Notebook
How do I connect my TV with the VCR Flat screen Samsung
here is the manual: http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000347&prd_mdl_cd=LS27HUBCB%2FXAA&prd_mdl_name=275T
the TV you are using has to be connected with AV devices and can only be connected to video. You need speakers if you want sound.
May 26, 2011 | Samsung SyncMaster 275T+ 27" Wide Format...
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Can i connect my laptop to the tv?
Yes there is a way to connect the laptop to the TV via VGA output. You can easily connect most of the laptops to TV via VGA and your notebook is fine for that purpose as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Toshiba Satellite L305-S5933 Notebook
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Hot to connect acer aspire mini laptop to digital lcd tv?
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
354 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
