Laptop shut down on its own
When i switch on my laptop it shuts down on its own after 15-20 min. if i continuously keep switching it on it shuts down immediately after 2-3 min
  • HW_Dude
    HW_Dude May 11, 2010
    You definitely got a temperature problem. If the CPU fan runs full speed, yet your computer still shuts down, then there is poor thermal
    contact between the heatsink and the CPU chip.
    You may want to consider having the thermal pad replaced.
    Hope this helps
  • blueextc3221
    blueextc3221 May 11, 2010
    is the CPU fan running? - do you feel air coming out of the vent??
    Scholar:
  • 51 Answers
Classic case of overheating.
Turn over notebook and remove bottom covers. clean out heatsinks near the fan.
The fan usually looks very clean, but look inside the fan housing and you'll probably find a blanket of lint/dust completely blocking the air passageways (even if they look clean from the outside).
If you remove the heatsink off the chips make sure you put on new thermal paste.
Some models it is very easy to get to the fans, others you have to fully disassemble the notebook
You could also try cleaning it out from the outside with an aircompressor, just leave it off for a day in case the is any moisture in the aircompressor lines. This may fix it but if its really clogged, you will need to open the unit and manually clean it.
HTH
JoshAU
Posted on Jun 02, 2009
Gemsound pa 1005 exa keeps shutting off
I Think that something like a transistor is getting hot and then shutting down. Exploring inside might solve the problem of what's getting really hot. You could even get some Servisol Freeze Spray, and wait for it to go off then spray it on the suspected part. That will cool it down and it should start up again. If it does come on, that part will have to be replaced.
Jun 28, 2012 | Gem Sound GemSound PA-585 2-Channel...
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
I PUT A POTATO IN FOR 6 MIN. AND AFTER ABOUT 2 MIN. IT SHUTS DOWN AND A MIN OR SO LATER IT STARTS UP AGAIN ,BUT THE TIME STILL COUNTS DOWN AND THE TURNTABLE IS STILL TURNING, AND YESTERDAY I HAD TO UNPLUG...
it sounds like it is overheating. but if only stops for a minute or so dont know if that would be enough time to cool off.When you start it up can you hear the fan running? does it keep running when it shuts down? if it's not running then thats the problem If the fan is running and shuts down when it shuts down then try shaking the door when you start it up the next time or you can try it the first time just to eliminate it being a faulty interlock switch. let me know about what you find about these two ideas.
Sep 02, 2009 | Sanyo Microwave Ovens
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Ignition problems
the problem is in the ign. switch. replace it
Jun 27, 2008 | 2003 Ford Ranger Regular Cab
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
