Question about Garden
Manual for Simoniz Honda Pressure washer s2600
I am looking for the manual for the Simoniz s2600 pressure washer with a Honda GCV160 5.5 gas engine.
Engine manual for the Porter Cable pcv 2250 pressure washer
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Jul 23, 2010 | Porter Cable Cable Commercial Pressure...
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Manual needed for Simoniz S1800 Pressure Washer
I contacted the Company in US.
Thank you for keeping in touch.
Jun 21, 2009 | Garden
Not getting any pressure at nozzle.
Can anyone Solve this? My simoniz S2500 gas powered pressure washer has low pressure coming right from the outlet. It used to be high pressure until now.. I think it has something to do with the pump and if so, is there anything I can do to repair this problem? The screen is good; water comes out of the hose good, wand is ok......Just that lower pressure is at the wand even at high settings....It comes in a form of a spray in both modes......
May 17, 2009 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
I REQ A NEW PUMP MANIFOLD CRACKED HAS ABOUT 5 MINUTES ON IT
Im looking for one too....If i find one i'll let you know....if u find one please also let me konw where i can find it. Thanks
Ravi_w15@hotmail.com
May 10, 2009 | Garden
How to disconnect power hose from s2600 simoniz gas power washer
Just unscrew it like you would a garden hose and pull it out.
Apr 24, 2009 | Honda Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Garden Logo
1,462 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
