Question about Karcher 2500 PSI Pressure Washer
Karcher K 2400 HH Pressure Washer no pressure
I have a Karcher pressure washer model K2400 HH that I got from Costco. It won't go high pressure. I checked everything according to the manual but no go. Karcher tech suggested that it could be a sticking unloader valve that I can clean and lube myself. They said "There are only two bolts that keep the valve cover in place so do not remove more bolts than this. Do not take any other bolts off or you will open the pump and lose oil. Typically they need to be cleaned and not replaced. Do not operate the unit with this valve remove or unbolted." However I don't see 2 bolts that will remove anything. Looks like 4 bolts removes the whole end piece. Suggestions? '
  • jeff64999 Feb 10, 2013
    I had the same problem. I took the cheesy black plastic thing off, lubed the part with lithium grease and it worked like a champ.
  • Aron Kerr
    Aron Kerr Apr 05, 2012
    This document has been moved on our website. Please visit the following link instead.
    http://www.landanorthwest.com/knowledgeb...
    Sincerely,
    Aron Kerr
    Landa Northwest
    www.landanw.com
On top of the pump you will see 2 screws or bolts after removing plastic cover. this is the unloader. pull off the cap and put some oil on top of unloader replace top and see if it works. if not will have get a pair of pliers and pull unloader out and clean. This will work had same problem with mine.
Posted on Aug 30, 2009
I had the same thing. Had to use Lithium grease to get it to work properly. Must take the cheesy plastic thing with the silver top off first to get at it. Only lubed the large o-ring. Works like new.
Posted on Oct 05, 2009
  • BRANDON SANDE Aug 24, 2012
    PULL UP ******* THE UNLOADER VALVE,ITWILL COME
What type of oil do you use?
What kind of oil is in the pump?
Posted on Jul 11, 2013
I have a K2400 HH pressure washer. When I started using the machine this year, the pressure would last for a moment or two than quit. When I would shut off the pressure and wait a few minutes and start...
sounds like a weak or worn out unloader valve spring.
MODEL DESCRIPTION PRICE SN-060-216 Pressure SpringKarcher/53323910 $5.90cart.gif
You can find parts online through Karcher or Ebay if you wish.
I hope this helps!
Feb 23, 2011 | Karcher Garden
Replace pump on a darcher k2400 hh pressure washer
There is a bolt item 8 below on the very end of the drive shaft that has to be removed before you can remove the pump assembly.
See page 16 item 8 of this Manual: (<-click and download
Then you should be able to remove the pump.
Thanks for using FixYa.
Kelly
May 11, 2010 | Karcher 2500 PSI Pressure Washer
Do I need to put pump oil on this k2400 I mean the
the water should take care of lube and cooling. word of warning...absulutely,positively,do not run this machine without water hooked up and running thru the pump. just a minute without water,and the pump will be junk!!!
Dec 21, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
Pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Jun 22, 2009 | Karcher 2500 PSI Pressure Washer
Removing unloader valve
If you can't get it out with needle nose pilers try turning the garden hose pressure on and the water should pop it out.
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
3,273 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
