Question about E-Machines M5312 Notebook
One long beep and two short beeps
I think that means I have a video error like something's wrong with the video card or motherboard. I just cleaned the fan, today, and it was working fine until the computer seemed to go into suspend. When I returned, I pressed the power button without thinking, and the blinking power light became solid; but there was no video. The buttons did nothing, and I couldn't use secure shell (ssh) to restart it. (couldn't access the port) So I held the power button until it cut off, and then, cut it back on; but it was the same. So I powered it off again and left it for an hour or so, and came back; and then, it was beeping. (one long beep and two short beeps)
    Guru:
  • 597 Answers
I believe that is a Pheonix bios and the beep code you gave indicates motherboard problems.
http://www.computerhope.com/issues/ch000607.htm
Posted on Jun 02, 2009
I have an MS9158E Mainboard. this computer has been a real workhorse. Today, it did not post on the monitor. Change monitor did not help. Did not post on network either. Do I need a new mother board? or is...
Remove the Power connection. Open the CPU Cabinet, Locate The RAM, remove the RAM by Sliding both Clips, Insert it Back to same Slot or another. Try to boot it again, if still same problem then, Change the Graphics Card with New one. If still have the problem then only Replace the Motherboard. Best of luck
Feb 03, 2011 | Matsonic MS9158E+ Motherboard
Hi! I have Asus m2n-vm hdmi motherboard, about month ago i've got problem: if computer works more than 12 hours, it freezes and works normally just after few hours "rest". Also, after shutdown...
Hi lvadim1993,
In other word your PC works intermittently. Here is what you have to do. Check and remove the processor cooling fan and heat sink clean the cooling fan and heat sink. If you have a thermal compound remove the old thermal compound and put a little amount at the center of the heat sink. Reinstall it back the processor cooling fan and heat sink and make sure It install properly even and snag tight. re plug in the cooling fan connector to the motherboard. If you have a video card remove and clean the video card connector and the cooling fan and heat sink with air blower same also to the memory card. Use the air blower to clean the motherboard and the entire internal of the PC. Reinstall the video card and the memory card and make sure that they are install properly. replug in the video cable and the pc power cord and turn on the PC. this will work. the computer is just over heating. I hope that this information will help you solve the problem.
HRH
Jan 05, 2011 | Computers & Internet
Loud Whining Noise from Motherboard on Startup
Whining noise is something in motion or moving.Does the graphics card have a onboard fan?Is it clean and free moving.
How about the processor fan? clean,free from wires or anything hitting it.?
Disconnect hard drive and see if you get the sound.
Jan 18, 2010 | Abit IP35P Motherboard
Continuous beep
This is most likely a memory error. You didn't say if you've done any work inside the computer but if you have double check that the ram is seated correctly.
You bios is award and these are the beep codes:
Beep code brief:
1 Long Beep: Memory problem
1 Long Beep and 2 Short Beeps: Video error
Continuous Beeping: Memory or video problem
Any other beep pattern: Most likely Memory problem
1 long Beep: Memory problem
Something is wrong with the memory installed. Check out the troubleshooting memory problems FAQ for details. Note that there could also be something wrong with just accessing the memory (ie the motherboard has a problem).
1 long beep, then 2 Short Beeps: Video error
The motherboard is not able to access the video card for some reason. Either the video card is not working, it's memory is not accessable, or it's BIOS may be corrupt. This error code could also mean something is wrong with the motherboard.
This is a tricky situation... likely the problem is either memory or the video. This can also be found when the motherboard is faulty.
Apr 30, 2009 | AOpen MX3L (91.88110.251) Motherboard
Motherboar fail, no video, power supply ok help
Firstly, remove the RAM and turn on the system, if you hear the beep sound continuously that means everything is perfect expect RAM.
Clean the track of RAM at both sides by pencil eraser completely.
Also clean the port of RAM.
Secondly reinstall the CPU with CPU FAN and also clean the FAN.
Third one is that remove all the add-on's card and than turn on the system.
Apr 12, 2009 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Overheat
check the motherboard fan and also system fan.
Jun 27, 2008 | Microsoft Windows Vista Ultimate Edition
PC has died !! I've disconnected all the HDDs, ROM, RAM, Video Cards and still dead. Power light comes on, CPU fan starts up, NO LIGHTS anywhere on the motherboard, two short beeps, followed by third beep....
based on your information the two beeps is an indication that you motherboard is alive and looking for a memory. is the video integrated or you use a separate video card? i think this has something to do with your video. if your video is integrated try putting in a video card
Jun 19, 2008 | Computers & Internet
DRAM Beep
Try to clean the bronze circuit of your VGA card and insert it again, if its the same Your video card is broken, you need to replace..
1 Long beeps means theres an error on your vcard / or theres a problem on it..
3 short beep means thats your RAM have an error or a problem on it..
Once the if the mbord doesnt gives any sign or a beep and seems to be blackout there could be a short circuit on your mbord to the parts with a connection to it...
Feb 02, 2008 | Jetway 939GT4-SLI-G Motherboard
No Display
Be sure that your power supply is working!
If the PS is working ,Try to examine your memory . if your computer getting long beeping. means that CPU is working if not beeping something wrong with your CPU. if beeping Unplug the memory clean it and connect it back. then test the computer. if doesn't solve the problem try replace the memory.
Dec 10, 2007 | Computers & Internet
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Sep 03, 2007 | Mach Speed (MSNV-939) Motherboard
E-Machines M5312 Notebook Logo
339 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
