Question about JVC Televison & Video
Black box covers most of the tv screen.
When we turn on tv, there is a brief moment of a station's programming, and then a black box appears covering all but about an inch all around of the show. As we change stations, the same thing happens, we see a brief 2-secs. of full screen programming and then the black box appears. Any ideas?
  • yeelange Jun 02, 2009
    Thanks Rockitman187. That did the trick. I don't know how we hit the closed captioning button to begin with.
    As soon as we hit the button, the black box disappeared.
    Thanks so much!
    President:
  • 2,559 Answers
Just use the remote to turn off the closed captioning,The button should be marked as CC or you can just go into the menu and turn it off.
Posted on Jun 02, 2009
TV does not autotune to all stations and does not store stations
The set has a EPROM somewhere that stores that info--either a stand alone one or one incorporated into the microprocessor the set uses.
The tuner if bad likely will not cause it to "forget" stored channels.
A possible way AROUND this would be the use of a cable/sat box connected to rear inputs on the set---you would sit on that input and change channels via the box which can usually be programmed to skip up/down channels you do not want---straight around the issue.
May 29, 2012 | Televison & Video
Just today a black box has appeared on my screen. It appears in the top right hand corner of the Tv and is approximately 6 inches by 6 inches. I can see that it actually works as when there is movement on...
It sounds like you accidentally activated picture in picture with a dead station tuned in or a different input selected for the P.I.P.
Start around page 52 of the user manual for instructions on this.
Your manual is here:
http://www.fixya.com/support/p232474-panasonic_th_42xvs30u_42_in_hdtv_plasma/manual-8012#
If you turn off the PIP, everything should go back to normal.
Feb 27, 2011 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
A large portion of tv screen covered by black
you need to get either a better rooftop antenna or an amplified adapter . it is undetermine which stations will come in for digital.
Feb 22, 2010 | Televison & Video
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Black Box appearing on my screen
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Emerson tv with dvd
Go to menu, and turn off all your caption options. This boxes are used for Text transmission. A few years back PBS use to run news briefs, using this option.
Sep 03, 2008 | Emerson Televison & Video
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Black square covering up most of the screen
Try goeing into your Menu and see if you have the closed Caption on that will produce a black box on the screen if you have the owners manual look in there,if you don't have it you can go on line and download it from the manufactures website under Downloads Good luck Walter Grzybowski
Sep 17, 2006 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
166 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
