Question about Char-Broil CharBroil 4637318 Grill
BBQ LOW FLAME WHEN ON HIGH HAVE NEW TANK ON IT CHANGE HOSE GOING FROM TANK TO BBQ HAD TANK CHEAKED FOR LEAKS OK TRIED OTHER TANK STILL HAVE PROBLEM. CAN YOU HELP ME IAM MUST FRUSTRATED I have a grill whose flame is low when the knob is turned on High. It is brand new and I accidentally threw the maunual away so I have no idea where to start troubleshooting.
  • 10,865 Answers
Your frustration is common because the new tanks all have a safety feature built into them which is a pain in the you know what. Unscrew the tank to reset the safety valve and then screw it in again. That should result in the valve being in the open position and working for you.
Posted on Jun 02, 2009
BBQ does not get hot enough to cook properly. All gas jets are clean as BBQ is almost new
blue flame? if flame is not blue, then air gap needs adjusting. if blue flame and burner control is on high, then could be your regulator. (assuming tank if full)
Apr 17, 2015 | Grilling
Low flame
turn everything off and disconnect the regulator from the gas tank
turn the bbq on high, every valve on high.
leave it like that for 3 minutes.
turn all the valves to off -- completely off.
reconnect the LP cylinder but turn the valve on very, very slowly for the first full 360 degrees.
that is the process for resetting the check valve safety feature which gets triggered by mistake from the presure of a full cylinder with the OPD flaot pressing on the liquid.
Jan 24, 2014 | Coleman Grill
Bought this grill in june/july. first tank worked perfect. tank went out while cooking. changed to new tank and lit her up. low flame and went out. looked at tank and found the valve and hose covered...
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Sep 24, 2011 | Weber Spirit SP-310 Propane Grill
I used our bbq a couple days ago and it was fine, now I am not getting a flame to any part of the bbq. Tried different tanks, still nothing. Do you have any ideas as to what it might be?
Betty, to solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 09, 2011 | Uniflame FG2204C Grill
Low flame. less than 1/4 inch high. Solution? Tried disconnecting/reconnecting hose to tank. Very little change in flame from low to high.
After you disconnect the hose from the tank, wait 5 minutes before reconnecting it. Then turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is fully open. Light the burner and turn it to it's highest setting. Did the flame height return to normal? I f so, problem solved. If it didn't remove and clean the burner and the venturi valve, Spiders like to build nest in them. If after all of this, the flame height still hasn't returned to normal and you're sure you have a good amount of gas in the tank. You'll need to replace the grill's hose/regulator assembly. You can find one at any home center or hardware store that sell gas grills and accessories. Take you old one with you for comparison purposes.
Hope this time, Your problem was solved. Happy Grilling!!
Apr 27, 2011 | Weber Baby Q Grill
Won't light properly or vary the flame
You're probably turning the LP tank valve on too fast. Close the tank valve, disconnect it and reconnect it. Then very slowly turn on the tank valve. Make sure all your grill knobs are closed. Light one at a time and turn to low setting. After they are all lit, slowly turn up the heat on each as needed. Hope this helps. Douglas
Jun 07, 2010 | Weber Q Grill
Heat and flame not as high as last year
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=31463&modelsID=129339&typeName=bbq This is what you need, Taking a air hose to regulators or controls at high force can severely Damage them.
May 18, 2010 | Weber Q Grill
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
May 18, 2009 | Weber Baby Q Grill
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
Char-Broil CharBroil 4637318 Grill Logo
584 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
