Question about Bunn GR10 Coffee Maker
Water wont come out of my bunn coffee maker
Purchased bunn coffee maker at yard sale. Brought it home and completely cleaned it out. After pouring water into it I heard the water heating up and could feel the heat so I know its heating up but the water wont come out.
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
  • 10,865 Answers
Chances are that the sprayer where the water enters the coffee grounds cup is clogged. It unscrews. You can run a fine piece of wire through each hole to clean it out or soak it overnight in vinegar.
Posted on Jun 02, 2009
Bunn coffee maker heats but wont pump water?
I thought these are pour over brewers? Which means you have to fill it with water in order to brew? It should happen when the unit is filled first, plugged in then turned on.(see link below for MFR instructions) Aloha! ukeboy57
http://www.bunn.com/sites/default/files/care-and-cleaning/43097_0002d01_velocity_brew_manual_english-_bt_st.pdf
Mar 11, 2017 | Bunn Coffee Makers & Espresso Machines
How do you clean the Bunn 10 cup classic comercial coffee maker it is a BX-B model?
To clean your brewer, with the machine still turned on, pour in 1 qt of white vinegar and let it sit in your brewer for 2 hours. At the end of 2 hours, you will flush it out with 8-10 decanters of water.
Dec 26, 2010 | Bunn 10 Cup Home Coffee Brewer
I bought a white Bunn GR-X home 10 cup coffee maker at a yard sale. My husband is in Afghanistan and has been wanting one for a long time. I got home and poured maybe 10 cups of water into it, turned it on...
It takes 2 full decanters to fill the tank. You fill the tank with 1 full decanter of water and pour it into the top and close the lid-wait 3 minutes. Then fill the decanter again and pour it into the machine and close the lid. Plug it in and wait 15 minutes for the water to heat it up. Then you will be ready to brew coffee. You will pour in 4-10 cups of water at the top and have your filter basket ready with filter and grounds. In 3 minutes, you will have your coffee. If you have any questions, please call customer service at 800-352-2866.
Dec 04, 2010 | Bunn GRX-W
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Just bought a Bunn coffee maker at a garage sale great condition how do you make the coffee I have poured water in turned the side switch on and the warmer switch yet nothing?????
The machine requires an initial set up to be completed before using it. Fill the decanter with cold water and close the lid. It will take 3 minutes to partially fill the water tank in the back. Then fill the decanter again with cold water and pour in and close the lid. Then plug in the machine and turn the vacation switch on the side of the machine on. After 15 minutes, you will be ready to brew coffee. Then you will get your filter basket ready with the filter and grounds. Pour in from 4-10 cups of water and place the decanter on the base. Close the lid and the coffee will begin to brew. If you will call customer service with the model and date code, a use and care manual can be sent out to you at no cost.
Sep 06, 2009 | Bunn NHB Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn commercial coffee maker does not pour water
clean your spray head by removing it and at the same time run the cleaning spring up through where the spray head screws to. before replacing spray head place your pot under and pour a pot of water through,to rinse.when done replace spray head .wait for it to heat up and your set to brew again...
Oct 28, 2008 | Bunn GR10 Coffee Maker
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Bunn GR10 Coffee Maker Logo
810 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
