Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer heats ok but drum won't turn
Heats ok but drum won't turn
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    its easy to remove the front. If i had to guess I would say it was the belt or motor...... If you feel mechanically incline you can remove it and use a flashligh to see if the belt broke? I can tell you where to get the part if need be. it may have fell off the moror also... let me know
  • 121 Answers
Dryer Belt broke or motor isnt working
Posted on Jun 02, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint CTD00 dryer, drum not turning
Provided you only have 2 wires to cap ,it does not matter which wire you put on terminals, as they are both common.
Assuming you got the right value cap, 8uf I think, and it still does not go, check for live and neutral to motor, if supply o/k then you probably have faulty motor.
If no power there check for bad or broken connection.
Pls rate this solution
Posted on Dec 15, 2008
  • 163 Answers
SOURCE: indesit washer dryer won't heat up in dryer mode
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
  • 212 Answers
SOURCE: kenmore dryer model:11060832990
sounds like start switch on motor bad.
Posted on Jun 24, 2009
SOURCE: worked fine until today. Not heating. Drum turns well
Ken,
I am diagnosing a similar problem in my dryer. Mine is a MDG4000BWW but the part catalog looks almost exactly the same. If you haven't done so already, make sure your vent pipe is clear. Since the air flow carries away the combustion gasses, there are safety switches to shut off the gas if the vent is blocked. If the vent is clear, take off the front cover by unscrewing the four screws that hold the door and door stops. The front panel should tilt forward and come free. The gas control is pretty straightforward. There is an ignitor that heats up and glows yellow. On my machine it is on the left hand side of the burner and is very obvious. If the ignitor does not heat up, that is probably the problem. You can confirm that the ignitor is getting electricity with a voltmeter. If you don't have one try the other heat ranges on the dial. It is unlikely that all the control positions would go bad at once, so if none of them make the ignitor work I'd recommend replacing it. If the ignitor works then a solenoid (electric control valve) should open and allow gas to flow into the burner. If the ignitor goes off without the burner starting, then the primary solenoid needs to the replaced. If the burner lights but does not stay on, then there are two potential problems. There is a flame sensor that detects the fact that the burner is on and sends a signal to a second solenoid to keep the gas on. It may be hard to tell which is the problem without a meter. My bet would be the solenoid. If the gas comes on properly and stays on for more than a minute or so, but then goes off and does not come back on I think you have a thermostat problem. There are two (on my machine) one to prevent overheating and one that cycles that gas on and off to maintain temperature. The high limit thermostat is to prevent fire if the cycle thermostat fails. All the parts are available online and range from about $16.00 to $35.00. Hope this helps - good luck
Posted on Jul 06, 2009
  • 2976 Answers
SOURCE: dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Posted on Oct 25, 2009
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Drum still turns but no heat where do i find the heater
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
128 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
