Question about Intex Easy Set 1500 Gph Filter Swimming Pool Pump
Will not pump when it has a filter in it
I have a intex about ground pool that I got for my kids. We got it last summer it worked fine all summer we took it down for the winter and now we have put it back up. At first it was working fine but the past few weeks it will stop pumping water you can still hear it running, You can put a new filter in it and it might pump 30 minutes or a day and it stops again. When you take the filters out they still look almost new they are not stopped up. You can take the filter out and it pumps great. It got me stumped. I could understand it if the water was dirty and the filters were stopping up but the water is clear and when the filters come out its hard to even tell they are used but if you put a filter in the pump it will stop working.
  • 110 Answers
Filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Posted on Jul 07, 2009
Index sand filter pump SF 20110 will not blow water into pool
I don't know how much time you are giving it, but sometimes when I start my pump, it'll take 20 minutes or so for it to start a full stream of water. Also, make sure the valves are turned to the unlock position on the incoming and outgoing hoses.
Jun 03, 2014 | INTEX Sand Filter Pump
Just replaced my 1000 GPM Intex filter/pump with the 1500 GPM. Worked great for about two weeks. Now it doesn't pump much with the filter in. Seems to pump fine without the filter.
The filter needs to be cleaned. the cartridge should be removed from the housing and sprayed on the o with a hose and sprayer. A strong, concentrated jet of water works best. I hope this helps.
Aug 15, 2011 | Intex 1500 Gph Swimming Pool Filter Pump...
Last summer we installed a Intex salt water filter it worked great for about 2 1/2 months. It stopped working, Checked the power supply nothing was coming thur it. Intex relpaced it under warranty. Started...
This could be a flow problem and you will need to check your pump baskets for junk and make sure your filter is clean. Also you can check your flow switch to be sure it is working.
Aug 13, 2011 | Intex Automatic Salt Water System for ...
My intex saltwater system does not fit on my summer escapes filter pump. My pool size is 16' x 42" and the pump sits on the ground. On end of the filter is high and the other is low (returm flow).
unfortunately every thing you mentioned is not reaaly important.
Bottom line is that Intex has there own size hoses and prevents easy installation with other manufacturers.
You will need to make a trip to home depot and buy a basket full of fittings and keep trying till one works
Jun 15, 2010 | Intex Automatic Salt Water System for ...
Will the intex saltwater filtration system work with the summer escape?
We, like others, purchased an Intex 56633E 2500GPH Intex Pump for our Summer Escapes 18 X 52 Pool. While this is not exactly the pump you are talking about, the installation is the same. It comes with the filter, hoses, and cut-off valves. It was easy to install, with a few modifications.
For those who need assistance on getting this to work with the Summer Escapes pool, here is what we did:
1. We installed the plungers that came with the kit on the pump, before the hoses. This was done to allow us to close them, so that we can clean the filter, when needed. They install without any modifications.
2. We installed the GAME 4552 Skim Filter Pump Adaptor (Avail. On Amazon) on the bottom of the existing skimmer assy. (You can skip this, and use the existing pump, if you wish. Just remember to remove the impeller assy, as it will reduce flow.)
3. We then cut off one of the threaded ends from each supplied hoses, just below where the flat part of the hose is located..
4. Next, we put teflon tape around the bottom of the Game adapter, and also, on the existing wall output tube.
5. Using 2 clamps for each of the connections, installed cut off ends onto the game adapter, and the output tubes.
6. We re-installed the existing C filter into the skimmer, and the basket.
7. Now, the easy part. We cleared all of the air per the manufacturers instructions.
8. Turned on the pump, and, were delighted to see more water move in the pool than we have ever seen before.
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Does not come on at all no lights no sound
No user fuse or reset
If you still have a receipt and it is under 2 years old Intex will replace it. Call them and they will walk you through it
In the mean time here is a link to manuals and videos
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 24, 2010 | Intex Automatic Salt Water System for ...
Pump is not turing on? Worked fine last year
These pumps are very cheaply made and getting even one year out of them is doing good. While it will be expensive in comparison to these cheap pumps, consider installing an above ground 1/4HP pump and filter skidpack instead. You can find these online and the results are far superior and the life span is years.
Mar 27, 2010 | Intex Easy Set 1500 Gph Filter Swimming...
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Easy Set 1500 Gph Filter Swimming Pool Pump Logo
381 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
