Question about Prima C2012 TV
Blue screen only
Tv comes on but no response from any controls
  • 378 Answers
Double check the input, the simple way is using a good DVD player and good A/V Cable. plug in the A/V cable in DVD A/V output, then plug the other plug into TV A/V input. Then set your tv to AV input. if nothing comes out even though the dvd player is playing. The TV AV switch maybe damaged.
Posted on Jun 02, 2009
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Aug 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
Blue screen
first , auto program you tv ,if still the same , your tv need to re solder. if you know how to solder,. Solder the tuner the jungle ic and system ic, but be careful of short circuit.
Oct 29, 2008 | RCA F32650 32" TV
Screen is too blue
You will have to take the front cover off, usually 3-6 screws holding from the back, when it does come off there will be wires to the control panel attached still. you will also have another panel to undo. after that there will be a block with 3 focus controls and 3 screen controls marked b g and r for the three colors. The blue screen control is the one you are looking for, be very careful the slightesr turn has huge response including shuting the tv off when you turn it the wrong direction to far
May 06, 2008 | Sony KP-51WS510 51" Rear Projection...
Red CRT is dim....
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Sep 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Prima C2012 TV Logo
157 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
