Question about Canon NP 6551 Black and White Copier
E540 Error The sorting unit makes nasty sounds and then throws the error. The used unit was just delivered. Is there a reset sequence? exactly, please can you tell me what is a cam?, do you mean the sensors located at the bottom?, indeed, nobody wants to fix my sorter, so i decided to fix it for myself, and i realized that is not so hard than it appears, the only problem is that i can't find the service manual neither plans of any kind, any clue?, i did get out all the bins and cleaned the bottom sensors and fixed some stuff i found, but i still got the E540,  thanks in advance, i got the canon np6045 sm if you need it
  • 66 Answers
The sorter bins are not lifting equally. find a tray to use on the side of the machine or find a table the right height to use to catch the copies. that sorter is not worth fixing.
Posted on Jun 02, 2009
I have fault code EP6on my sagemcom DTR94 and unit stuck and cannot access any menu
Michael,
If you do not have your manual you can probably get it online at the manufacturer's website. Error codes are very specific. Most printers have a sequence of keys that you press in very precise order to reset the printer to default factory settings. This may be what you need. Don't throw it out yet!
A
Dec 03, 2016 | Office Equipment & Supplies
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Casio Ce 4700 Ope error appears. How can I fix as I can't use till
Hi. Did you get it going?
Ope error just means you pressed an incorrect sequence of buttons. If you still have trouble, tell me exactly what buttons you pressed to make the error appear
Apr 30, 2016 | Retail Supplies
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
I have a Canon NP 4080 with an error code E540. When I looked it up it read: lateral movement motor lock. It's an old machine; would like to fix it myself. Any ideas
Hello
According to Cannon
the error E540 is the Stack shift sensor error which may be damage or gone bad, it is recommended that you may consult Cannon Technician for repair.
Hope this helps, good luck
Jan 06, 2011 | Canon imageRUNNER iR C4080 Color Copier
We have a portable air conditioner. It keeps
Follow the steps below....
panel.
button.
Jun 26, 2010 | Heating & Cooling
E540 Error
The bins go up & down on cams and they poppped out of place. It needs to be taken apart and the bins need to be reseated. You can call me at (561)319-8253
Apr 09, 2009 | Canon NP 6551 Black and White Copier
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
ARF120
If you have the error code E1 on the LED temperature display. This error code is intended as a reminder for the user to clean the air filter every 720 hours . I have a sharp and I don't know what model you have but you may check the manufacturers web site for a instruction book but on my unit you have to do the following
panel.
button.
after following this procedure to clear the nefarious E1 indication, you should obtain
another 720 hours of cooling bliss
Jul 13, 2008 | Sharp AFR120FX Air Conditioner
Canon copier np 6545
E540 is a sorter/collator problem
You can unplug the sorter and move it away from your copier then swith off then on again and the copier will work and you can still sort via the document feeder.
here is the error code disription...
E540
Cause..
• Bin shift motor (fails to rotate)
Discription....
• The operation does not end within a
specific period after the motor drive
signal has been generated.
• Clock signals from the clock sensor
of the motor are absent for a
specific period.
• The input signal from the lead cam
position sensor does not change for
a specific period.
Jun 08, 2008 | Canon NP 6545 Copier
Canon NP 6551 Black and White Copier Logo
459 people viewed this question
old marine
old marine
