Question about Leviton 5225WSP Switch and Outlet
Installing a Leviton 5225 switch with outlet.
I want to increase lighting over a work area. I have an unswitched florescent worklight that I thought I could control by installing a Leviton 5225 switch with outlet.
There is an available standard outlet with two receptacles. I believe it must be in the middle of a run of outlets as there are two black wires and two white wires.
I tried wiring the switch but the circuit breaker keeps throwing. Is it possible, and if so, how do I accomplish what I need?
Thanks
  • 10,865 Answers
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Posted on Jun 02, 2009
Auger does not turn to dispense ice in Ice Maker of Frigidaire refrigerator ModelGLHS66EJW. Icemaker still makes ice correctly.
Without seeing it Im guessing. Sounds like one of the small plastic gears inside is off track.There should be like a cover on the outside with 4 screws to open it. Make sure the shaft is turning when the small motor engages.Somethimes they get off track while manually shutting off ice maker manually using the bar
Aug 11, 2013 | Leviton 10 Brown Switch Outlet...
Light switch outlet
Sounds like you are wiring a combination switch and outlet:
Open following link for illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
May 24, 2012 | Leviton Combo Switch Receptacle - 5225-T -...
I AM TRYING TO REPLACE A LEVITON 5225 SWITCH IN MY KITCHEN. DO YOU HAVE WRITTE INSTRUCTIONS ON THE NET AND IF SO, HOW DO I DOWNLOAD THEM, OR BRING THEM TO MY COMPUTER FOR READING?
Leviton 5255 is a switch-outlet combo
Open following link for illustration and written instructions for combo wiring:
Add a comment if you have trouble with wiring.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Leviton 5225WSP Switch and Outlet
How do wire this so that the switch controls the outlet. We are installing this over a work bench to turn off and on a light over the bench that is pluged into the outlet.
On one side you will have one brass screw and one silver screw. Connect the hot wire (usually black) to the brass screw and the neutral (white) wire to the silver screw. That's it, it comes from the factory ready to switch the outlet.
Aug 24, 2011 | Leviton 10 Brown Switch Outlet...
Leviton 3-way wide view motion activated light control, flickers, then blinks then shuts off after installation. Installed in a hallway with florescent lighting.
Some switches are not designed to work with the florescent bulbs. It's a matter of them trying to push a starter for the light. Check the package and see if it's compatible.
Jan 06, 2011 | Leviton Electrical Supplies
I have a Leviton 5225/702. I want to control the receptacle/outlet with the switch. I have not broken the hot tie and I have not used the brass screw. I tried 2 hook ups without success.
Assuming you have a tie on only one side, you should not use either screw on that side of the unit. Connect your hot wire to the screw on the other side of the unit on the end closest to the switch. This should be an isolated brass screw. This will allow the hot wire to feed through the switch, then through the hot tie to the outlet end of the unit. Connect the white neutral wire to the other screw on the same side that you connected the hot wire. This should be an isolated silver screw toward the outlet end of the unit. Connect your ground wire to the ground terminal. good luck Al K
Dec 17, 2010 | Leviton 5225WSP Switch and Outlet
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
How to install leviton 5225 wsp wall switch/receptacle with three wires wilsoncarey@att.net the old switch has a pilot light /switch /receptacle
For this combo , the white wires connect to the two silver screws on one side of the combo .The black power wire connects to the screw next to the switch. IF you want to have the receptacle hot all the time then jumper the hot black from the switch screw to the receptacle screw. The screw in the center is for the black wire from any lihghts that you want to control. IF it is the receptacle that you wish to control with this switch .. then the power connects to the screw next to the switch and the center screw jump a wire to the screw next to the receptacle
Jan 15, 2010 | Leviton 5225WSP Switch and Outlet
Old switch only has three screws, with a white wire connected to the sliver screw and a green wire connected to the copper screw and the red screw is on the other side. Where does the red wire go on the...
I don't understand your problem. Green wire is ground goes to the yoke. it should not have any current on it If it does sumbody messed up real bad!
a combo outlet/switch has three brass screws and one nickel screw. yoke should have a green hexagonal screw.
Oct 25, 2009 | Leviton Combo Switch Receptacle - 5225-T -...
How to wire combo switch
you should have 4 wires total (not including grounds, which get twisted together and connected to green screw) you have to know which is the power lead, and which goes to the light! 2 blacks, and 2 whites ...the 2 whites go together and connects to the silver screw, and the 1 black power lead goes to the gold screw, the other black wire(to the light) goes on the opposite side of switch above the silver screws on another gold screw
Apr 06, 2009 | Leviton Combo Switch Receptacle - 5225-T -...
Leviton 5225WSP Switch and Outlet Logo
1,264 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
