Need image for motherboard to know where on/off connection is. Also have a set of numbers, but so far none match as model #. Want computer # and system board #
SOURCE: Compaq for Evo D300 Motherboard
The link is helpful but does not show how to wire the power switch, power led, hdd led and reset switch. Need this information to transfer board to another case.
SOURCE: Compaq Motherboard 211054-001 (chipset i815,CPU PIII X86 family 1000 MHz
for updates of bios you need to know the mother board model number sir.
and this can be found from the my computer properties also.
please have a look
SOURCE: only beeps with my Compaq motherboard(239116-001)
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Go to the above site contains beep codes for compaq
I believe your ram is faulty or needs removing and refitting
SOURCE: Add Memory In Compaq Deskpro 6000 P2 Shuttle PC?
Before you get to that you may want to see what type of memory and much you can upgrade you shuttle. Go to http://www.crucial.com/ and do a scan to see what memory you have in the system and if it worth upgrading. Then go to hp website and get the manual to find the motherboard.
Please rate, Thanks.
SOURCE: My computer have got know Ethernet drivers,the
upgrade your ethernet or network adapter drivers from the compaq website.... in that look for your computer model .... http://www.compaq.com/
