Question about Refrigerators
The front of the divider wall between the refrigerator and the freezer is extremely hot. The front only not the insides. Also some what warm is the outside of the freezer side but not as hot as the other part. Mod: ED5FHEXNT01 Serial: SS4132379
  • 15,935 Answers
CLICK HERE for blowout diagrams of your fridge.
It sounds like you have a condenser issue, either the condenser fan is not turning and getting air movement across to condenser coils or the condenser coils are clogged with dust, hair, carpet fiber or whatnot.
Try cleaning the coils(under the fridge) and checking the fan(at the back of the fridge, behind the panel) for proper air flow. You should feel warm air coming from the fan housing.
If the fan and condenser are clear of dustbunnies and the fan still does not operate - Most likely the condenser coil fan motor has failed.
It will be part #24 on THIS particular blowout diagram.
CLICK HERE for a direct link to the part to order.
If you require further help, please use the "Continue With This Expert" option so we are connected in the future.
Thanks for using FixYA :D
Posted on Jun 02, 2009
The divider wall between refrigerator and freezer is extremely hot
Condenser is dirty our the condenser fan not working. Remove back and check fan. If not working check voltage coming to fan. If 120 volts, replace fan. If no power, bad board, located far left corner next to compressor.
Aug 17, 2012 | Refrigerators
My side by side refrigerator is very hot at the divider wall between the Freezer and refrigerator just below the door handles on the front of that wall.
there is a hot gas line that runs there to keep condensation from forming,if it is hotter than it used to be suspect the condensor fan motor
Jan 10, 2010 | Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
Possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Mar 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frig is hot only in upper front (divider) where two doors meet.
need to see if your fan is running in the freezer side if not replace it if it is then check to see if you have frost on the back lower wall inside the freezer if you have frost then you have a defrost problem
Dec 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Heat build-up
Had this same problem and turned out that the coils at back of fridge and below doors were covered in dog hair. After vacuuming, area is no longer warm.
Aug 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Hot
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
