Question about LG Prada KE850 Cellular Phone
What does it mean format not supported ?
When i download music onto my phone and then i go to play it,it says format not supported and i don't no how to solve it.? But also on other music it works perfectly???
SOURCE: MP3 File Format
Posted on Nov 21, 2007
  • 19 Answers
SOURCE: what does "synchronize to continue music subscription" mean
the best way to put music into the mp3 player is by using windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Posted on Jan 24, 2008
  • 96 Answers
SOURCE: Music not playing on replacement phone.
If you downloaded your music from the internet, you can go to your cell phone provider internet account a re-download again into your cell phone. Customer service can guide you thru.
Posted on Jul 08, 2008
SOURCE: once downloaded on to mp3
once downloaded on to mp3 player GOGEAR wont play music only says file format not supported
Posted on Aug 15, 2008
  • 4 Answers
SOURCE: cant get music
I have this nasty little player too, and it has caused a lot of grief including suddenly zapping all the files I'd put on it inluding the stuff that Laser pre-loaded into it. Be warned, this player is very prone to errors so it can't be relied on.
If it is under warranty you can take it back. Otherwise you will probably have to look at reformatting the player. Not a big job, but before you do this, copy everything off it onto your hard drive.
Reformat by connecting the player to your computer and finding it under My Computer. Right-click on it's name, and select 'Format'.
Format it in Fat32 which will probably be shown as the default in the Format window.
When it's finished you should be able to reload the player with a bit of music, then disconnect the player and test to see if all is ok.
Laser have a website if you google it, and a simple Faq. Writing to them about the problems with the player and seeking some solution brought no response for us. Good luck. When it's working you can forgive it the grief it causes.
Posted on Jan 15, 2009
  • 8596 Answers
SOURCE: MP3 formating
Here's what you want to do. Use Windows Media Player to re-Rip the CD's in Mp3 format. Go to Windows Media Player 11 --> Rip --> Rip Options --> Format --> Mp3 (you can get to Rip options by moving the mouse over the Rip tab, and a small black arrow will appear - click on the arrow).
Once the songs are in true mp3 format, you can then use the Sync tab in Windows Media Player to transfer the songs.
Unfortunately, many of the newer Philips players do not recognize DRM-encryption, which is why the songs would have worked in one player and not this one.
You have to get Rhapsody's Mp3 only service - I repeat, MP3 ONLY. No other level of Rhapsody service will work with the newer Philips' GoGear's - which is funny, b/c Philips co-branded with Rhapsody on the newer players. Rhapsody is not your only choice, but you must ensure that the files you are downloading are in Mp3 format.
-Tha Mp3 Doctor
Posted on Feb 07, 2009
0 characters
1 Points
Memory card. !! please help );
Don't know much about the Samsung phone; Can you put music on the 1 Gb memory card from another source (like a computer) and have it recognized by the phone?
Does the phone require music in a particular format? For example, if the phone recognizes .mp3 music files, but all your music is in Ogg Vorbis (.ogg) files, you will not be able to play them on the phone.
1) Find the Samsung phone manual (online?) and see if it requires music files to be in one format, or another.
2) Try loading music, in the proper format, from different sources onto your memory card.
Best of luck!
Nov 12, 2011 | Samsung Cell Phones
Need to view themms recvd on my non gprs hndset
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
Apr 11, 2011 | Nokia Cell Phones
Cara mendownload ultra mp3
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3 player.
Mar 13, 2011 | Nokia 6280 Cellular Phone
I hav the music
In this problem the music did you load to your player is not supported. To fix this problem make sure that the the music have same format to your old music. For example your player will not play FLV format but it will play itunes. So you need to convert the format to itunes.
Aug 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Micro SD card
sharp, you have to format the SD through your phone and then copy the music to the folder provided by the phone for the music. make sure you check the playing / bitrate / file type of audio file that the phone is limited to play.
if you have other questions just lemme know
Sep 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
I cant have my own mp3 songs for my ringtone on my LG Chocolate. it keeps playing the Ring 1 ringtone.
You can: MP3 Player * Download and listen to music with the built-in MP3 player.
* Don’t settle for boring polyphonic ringtones, select an MP3 as your ringtone. (Also supports AAC, AAC+, AAC++ and WMA formats)
* External MP3 button for easy access to your music.
* Graphic equalizer with 6 sound effects to choose from (General, Classic, Jazz, Pop, Rock and Bass).
You should try to find a music or download some mp3 music and when playing click on set as ringtone.
Jul 28, 2008 | LG Cell Phones
Downloading music into Kingston 2GB SD card on Nokia 6234
It's possibly not properly formatted type of AAC file that uploaded into your cellphone, that when you try to play the cellphone cannot support to play it and that it gives a messages like corrupted type of file..
Hope it helps
Pls. rate and hope to hear more from you
Feb 10, 2008 | Cell Phones
Samsung G600
Ur handset support these types of music and video players (MP3/AAC/AAC+/e-AAC+/WMA player) So please confirm the format of the songs which ur r transeferring to ur handset should b according to these format.
Oct 10, 2007 | Samsung SGH-D900 Cellular Phone
Motorola razr
see is that file wma.
Apr 01, 2007 | Motorola Mobility RAZR V3
Cell phone
Solution ... Get a new phone or go steal some more music that works. Try your local record store they have lots of things to take for free if you can run faster than they can then take it home rip the song(s) that you want in the correct format then put it onto your new phone. Thanks I like **** A LOT I mean seriously A LOT
LG Prada KE850 Cellular Phone Logo
218 people viewed this question
Top LG Cell Phones Experts
Scott Fryer
Steve Sweetleaf
Steve Sweetleaf
Jeremy Murray
Jeremy Murray
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
