Question about Vizio SV470XVT 47 in. LCD TV
No digital signal search
I have a vizio l42hdtv10a that has been always connected to cable or sat. But now i have it set for antenna over the air brodcast and I can get the analog signal in the tvs auto search but I can not get the tv auto search feature to look for digital signals. yesturday morning the digital scan stated and I was rec. digital channels but i shut the tv off to leave for the day. And when i got back i was unable to get the digital search to start. Any help would be great on what might be wrong or what i can do to make the digital scan work
Thank you
Christian
  • 22 Answers
Check your manual to see if it has 2 tuners, digital and analog. If it doesn't have a digital tuner, you will need a converter box.
Posted on Jun 02, 2009
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Sudden no signal on digital channels on a Vizio VX37L
That may not be correct. You would not lose all your digital channels. Vizio has an un-addressed problem with losing digital stations. Multiple threads are posted due to this problem, which is why I am on this site. I have lost all digital stations on CATV connection. The Toshiba set in the next room is getting over 150 DTV channels, the Vizio, only analog. Zero Digital.
May 23, 2009 | Vizio VX37L Television
Frame periodically freezes on Vizio 37'' TV
Your statement is confusing. Why? because you stated " This tv is hooked up to an Antenna with a Booster", then you said it's connected to Cable Tv. I will answer this both ways for you.
If your on an Outside Antenna or Rabbit Ears, even with a booster, if the signal is not good prior to getting to the antenna then a booster only amplifies what it see's and that may be as we call it, "garbage". In a HDTV the freezing can happen when that situation is at hand, however if you are on Cable and we know the signal is clean ( we hope? ) then the problem is with the software in the set and should be looked at by a service center, or if it's right out of the box then I would exchange it.
In digital technology there's no maybe, it's yes or no! If the signal is not what's required, then you get what your experiencing now, IF, there's nothing wrong with the set, and there may be. I just repaired another brand doing the same thing and it was the Main Control Module. So, I hope I helped you in isolating the problem. Please keep me posted...
Feb 26, 2009 | Vizio SV420XV 42 in. LCD TV
I can't get a TV signal on new 22" VIZIO
If you are getting the "No Signal" message you need to connect an antenna or cable to the antenna input. You also need to go into the menu for your signal source and select ANTENNA or AIR if you are using an antenna OR CABLE if you are using cable.
NEXT YOU WILL HAVE TO SCAN IN YOUR STATIONS !! This is not like the old analog sets that plug in and run.
The instruction manual will give you precise instructions.
Feb 19, 2009 | Vizio L32 32 in. LCD HDTV
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
Vizio SV470XVT 47 in. LCD TV Logo
748 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
