Question about Fisher and Paykel GWL11 Top Load Washer
Will not wash it syphons water in the wash mode
My fisher and paykel washing machine siphons water in the wash mode it will not fill up to start a wash
  • 30 Answers
The mixing water valve isn't shutting of letting it come in slowly. Replace valve. If not filling up may be caused , drain hos emaybe to low to ground. Should be at least two thirds up the washer.side.
Posted on Jun 02, 2009
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Washing not getting clean
ok, try this before you consider removing the bowl. 1st-- buy 2 pkts of bicarb of soda. 2nd---make sure machine has no clothes in it. 3rd-- empty the 2 pkts of bicarb of soda into the bowl. 4th-- select traditional wash mode , high water level, hot water fill. 5th-- push start. 6th-- let it fill and wash for about 5 to 10 min, then turn the machine off. DO NOT LET THE WASH CYCLE GET TO THE DRAIN OUT STAGE. ok now the machine is full water and bicarb of soda and turned off, LEAVE IT TILL THE NEXT MORNING.-- In the morning select traditional wash mode, high water level, hot fill , then push the start button. let it go thru the complete cycle and all the lint and dirt should be removed from the bowl. by the way once it has started to wash lift the lid and see if the agitator is working. good luck and please reply to tell me how you got on.
May 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher & paykel IW810 washing machine that will not fill the bowl with water. While filling, it is also pumping the water out, in the autowater level sensing mode. I have gone into the command...
hi, reading your posting it tells me that the machine will fill on traditional wash but on auto fill mode it pumps the water out at the same time it is filling. i"m pretty sure it is your diverter . on auto fill mode it fills a little bit then the pump comes on and recirculates your water by pumping the water from the bottom of the bowl to the top of the bowl over the clothes. on auto fill mode it also activates the diverter to pump the water back to the bowl. on your machine the diverter is stuck in the drain out position so when it trys to recirculate the water it drains out the water instead . the problem could be a faulty diverter, control module or a broken wire.hope this helps, please reply if you need more help. good luck.
May 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washing machine fills and won't stop filling...
If the water stops when you shut if off at the wall you have a bad cold inlet valve, or the valve is getting a constant "open" command from the controller and thus the controller is faulty.
Jun 18, 2009 | Fisher and Paykel (IWL12)
Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Aug 10, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
151 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
