Question about HP Pavilion dv7-1130us laptop
HP Pavilion Laptop shutsdown randomly, need help.
Hi, my HP Pavilion Dv7 1130us laptop has started shutting down on its own lately. It happens at completely random times, and I am unsure what the problem is. I know there is a error occurring, though, because there is a error popup that shows when I turn my laptop back on. Here is what the error is:
BCCode : 40000080 BCP1 : 8A57DAD0 BCP2 : 89FF6F30 BCP3 : 8A234F44
BCP4 : 00000001 OSVer : 5_1_2600 SP : 3_0 Product : 768_1
I am hoping that someone will be able to read that and make sense of what is causing the problem. This never happened for a while, and I havnt really done anything drastic with my computer lately. Any recommendations? Thanks!
  • pickmynose May 11, 2010
    Did you update your virus protection? And update your HP with Windows update.
    Guru:
  • 597 Answers
This looks like a bad memory stick. That looks like a memory address where the error occurs. Keep track of the messages you get and see if they are similar. If it's a memory address you may run the computer for quite some time or a short time till you use enough system resourses to fill up the ram to that bad address then it will die. The confusing part is it shows the program or device that was loaded into ram that failed and sometimes you think it's that program or device rather than the ram that caused it. In this example it shows possibly 4 addresses. 40000080 8A57DAD0 89FF6F30 8A234F44
Three of those are pretty close together. If you see more that start with 8A or 8B I'm maybe right.
Posted on Jun 02, 2009
I have a HP Pavilion DV7 and it keeps shutting down at random times.. When I turn the laptop back on, it starts up normally besides the improper shutdown screen. It has only happened twice, but its been...
some times can be like as thermal shutdown.
you can check it when using get so hot the back side of the laptop.and you can see reduce the output
of air flow from the cooling fan.and that air flow is get very hot.
for that problem, need to service the cooling fan.
other vice need to check the battery. its go bad, via in small power drop pc goes off.
Dec 05, 2010 | HP Pavilion dv7-1240us Notebook
My laptop keeps shutting off it is a hp pavillion dv6000
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 16, 2010 | HP Pavilion dv6000z Notebook
My hp pavilion dv1000 fan turns on for a little bit then turns back off.Do I need to replace the fan?
Are you having any problems with the laptop overheating or shutting down unexpectedly?
Generally the fan should only run as much as it needs to in order to maintain an optimal temperature. the fan will be turning off as the laptop will be cool enough. if however, the laptop is very hot to touch you may have a faulty sensor telling the fan the laptop is cool when it isnt. this generally leads to the laptop crashing or shutting down though if thats not happening i recommend contacting HP for guidance.
it is most lekely functioning properly if you arent having any other adverse effects
Thanks
Dec 21, 2009 | HP Pavilion dv1311se PC Notebook
Hp laptop shuts itself down
Laptops are designed (by software) to shut themselves off as a protection measure. The most common problem is high temperatures. Do you hear your fan racing while you are using it? Do you sit your laptop on soft surfaces (like the bed or carpet floor) while using it? Do you smoke around your laptop while using it? These are common things that cause high temperatures on your laptop and will cause it to shut down. May not be your case but just a though. I would take it somewhere or open it up yourself(if you are pass your warranty time ONLY) and clean out the dusk with some air.
Hope this helps!
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion dv5-1000us Notebook PC
Hp pavilion dv2000
hi friend
u r laptop has been infated by virous u have need a good ntivirous software insatll with a letaest update & scan ur laptop
ur problem will slove
Mar 31, 2008 | HP Pavilion dv2000t Notebook
Help my laptop keeps shutting down
seems like it mioght have the blue screen of death. go to google, and search for a program called "Bart PE" download this program, run it and let it burn to a CD. Now, boot the laptop from this CD, and let it load. Now click on go, and find the command prompt. type in "CHKDSK C:/r" and let it run. once it finishes,l reboot and take the CD out. Now your laptop should work perfectly. Best of luck dude ;)
Feb 28, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion zd8000 unexpected Shutdowns
Hi, There might be 3 possibilities why your laptop is shutting down: 1. You have a shortcut key in your keyboard that is pressed (accidentally or reacting to other keystrokes) that is configured to shut down your laptop; 2. You have a virus that is programmed to shutdown your laptop after a pre-determined amount of time; and/or 3. Your battery and/or AC adapter is no longer capable of supplying the power needs of your laptop. A few things you can do: a. Verify/Check if you have enabled any key stroke shortcuts for a quick shutdown; b. Check your Control Panel, Power Options, Advance tab, for any autoshutdown features, disable; c. use a known good/updated anti virus program and scan your drives. It might also be a good idea to run a program similar to Ad-Aware to scan for malicious ads; d. Charge your battery overnight and see if the problem persists. Or run the laptop with the AC adapter always plugged in to the mains and to your HP Pavilion ZD8000. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 01, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion dv7-1130us laptop Logo
218 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
