Question about KitchenAid KUDI24SE Built-in Dishwasher
Cant get impeller off
I cant get it off
  • 121 Answers
This may be a problem being water has seized it up you may need to get a pullet puller to get it off
Posted on Jun 02, 2009
How do I remove whats left of the impeller?
what remains of the impeller will need to be heated up evenly
and pressed/ rocked loose carefully
being fused expect shaft damage
if no room to work in the space that is there
you are up for a new shaft and impeller
Oct 10, 2016 | Pool & Spa
Cant remove broken impeller
Lift off. You may have to attempt to pry it off with two screwdrivers. Other method is to hold it by the impeller while someone takes a brass punch and a hammer and gently hit the end of the shaft to knock it free. Try to avoid damaging the shaft or you will have to dress the shaft up to get the new impeller on.
Aug 20, 2012 | Beckett Waterfall Pump W5000 4983 gph
Pump turns on but the impeller does not turn. I can turn the pumpo on but until i make the impeller move it will not turn. It is straining trying to get the impeller to turn. Once the impeller is turning...
sounds like your problem is the centrifugal switch inside the motor housing or the start windings in the motor are bad. Not sure about your peticular pump but most submersibles are filled with mineral oil, take care to save it when you disassemble, it needs to go back in
Jul 02, 2010 | Little Giant ES40D120 410 HP 60 GPM 10' ...
How to disassemble impeller on rs1000 hayward pump
OFF TO THE LEFT FOR REMOVAL OF A IMPELLER BUT SOME MAY HAVE A SCREW IN THE CENTER IT IS A LEFT HAND THREAD SO IT OFF TO THE RIGHT.. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY TO HAVE IT DONE RIGHT
Jun 29, 2010 | Hayward 1.5 Hp Northstar High Performance...
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a diamond pump modlel # 560549 i am trying to take it apart but i cant seem to get the pump seperated from the motor.
Of course you can't get it separated especially if the pump housing is still intact. Please do this;
1. Open the screw or bolts holding the front pump
casing.
2. Now, you can see the rotating part of the pump,
that is the impeller, and the cover called the
diffuser.
3. Take the impeller cover off, and see if the impeller
is mounted and locked by a nut at the pump shaft.
Or, screwed to the pump.
4. Take the impeller off from the shaft by taking off
the nut or unscrewing it counter clockwise.
5. Take the mechanical seal at the back of the
impeller off from the shaft.
6. Now, you can separate the motor from the pump.
Hope this will help you.
Nov 21, 2009 | Plumbing
Homemaker HMWM8000 shows E2 error and will not pump out water
Maybe just a blocked filter?
If the waste pipe is clear and nothing in the filter, the pump is worn or faulty.
Remove waste pipe and lay it flat on the ground to drain.
Hope this helps
john
Aug 27, 2009 | Washing Machines
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Removing water pump impeller
you might have to split the case to get to the back side of the impeller.
Mar 28, 2009 | 2004 Yamaha YZ 125
Sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Jan 09, 2009 | Toro Super Blower Vac
Dishwashers Logo
97 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
