Question about True TD-65-24 Commercial Refrigerator
Keeps running and freezing eveything, replace temp switch still freezing up
We have true cooler tuc48, it keeps freezing up, I just replace the temp control and it still seem like it wants to freez up, the long temp wire was not hooked up to anything it was just setting on the top of the coils and that what I did with the new one. is there a place that the temp wire needs to be pluged into.
    President:
  • 1,902 Answers
No the temp wire should be not on top of the coil but running down the middle all the way down to the bottom of the cooler. Try this first and if it doesnt work let me know
Posted on Jun 02, 2009
I use my True single door cooler for flowers. How do you adjust the fan so I maintain a 90-95% humidity ?
Unless this is specifically designed for this application, the only way to control humidity is to keep the temp fairly high. Part of the cooling process includes removing moisture from the air. In coolers, the fans run 24/7 unless specifically designed otherwise.
Jul 20, 2017 | True Refrigerators
My True TSD-33G freezes drinks overnight.
T-stat is overshooting or contacts on t-stat are sticking, replace t-stat and problem should go away. Don't forget to clean your condensers. That was just a helpful reminder.
Apr 02, 2014 | True TSD-33G Stainless Steel Cooler...
True 334g cooler was freezing things inside, there seemed to be no way to set thermostat where it would work properly. It was either freezing things inside or not cooling at all and now freezes up the coil...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 25, 2011 | Refrigerators
I have a true tuc48-f freezer..Problem: Frost build up to the point that the doors freeze shut and I have to scrape the ice off. Also at time it make a rackety noise like the fan hit solid ice.
It seems you have diagnosed your own problem.
Check the defrost circuit. It appears your defrost cycle is not working.
Also,check the door seals closely.
A loose or broken door seal can contribute to these symptoms as well
Sep 17, 2010 | True TUC48FADA Freezer
Cooler gets to cold
Try cleaning the condenser coil.
Jul 07, 2010 | True GDM-69 Refrigerator
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes the beer. is this a problem with the thermostat or something else?
This is probably the thermostat stuck closed and bad. Turn the tstat all the way to left or counter clock wise. The compressor should turn off.If the compressor continues to run the tstat is stuck and bad. A good replacement tstat would be Ranco # A12-1560.
Nov 08, 2009 | True TD-50-18 Beverage Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
True TD-65-24 Commercial Refrigerator Logo
509 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
