Question about HTC S710 Smartphone
Restored factory settings now all in chinese characters
I wanted to remove all my data from contacts, calendar and thought a short cut by restoring factory sttings, now all is in chinese :(
from the icons i can get to the SETTINGS but there after I need guidance on what position from the top I have to scroll to Regional Settings and than again on what position is LANGUAGE in order to get back to english please HELP
4 Suggested Answers
  • 59 Answers
go the system seting 设置/电话设置 then find language setting=语言 see if you see a word english, if you only see 中文 or 中文简体...........i have nothing to do about it, unless relfash the rom of the wm6.1
Posted on Dec 23, 2008
  • 4 Answers
SOURCE: change language to english
Go to start, touch, the touch settings, then touch system, then touch regional settings. change the language required, preferably english(UK) or english(USA). This should solve your problem.
Posted on Apr 27, 2009
  • 326 Answers
SOURCE: Can some help I need to change the language one my
The version of ROM loaded on your phone is only for English locale. You will need to either contact your provider, or obtain a Spanish ROM and re-flash your phone.
Re-flashing your ROM will void the warranty, and is grounds for fines on certain carriers. Please check with your provider/carrier first before attempting this method.
Also, Flashing can cause the device to become permanently defective.
As far as information for directly solving your problem, I have flashed my T-Mobile Dash so that it runs on an Original S620 ROM, obtained through the internet. The version of ROM that I was able to obtain only has English and French. However, you may be able to find better information and the files you need from the site below.
Posted on May 04, 2009
SOURCE: My HTC P3450 comes only with the chinese
click start and go to settings
click system and go to regional settings,select the region you want and exit.
Posted on Feb 28, 2011
0 characters
1 Points
Hot Sync deleted the entire calendar on both the handheld and the desktop. Contacts are still intact.
Hi Tracy,
Palm creates a backup file of your data so you can restore that file as long as you have not tried to sync your calendar again (that would create another backup file that would be blank.
Here is the link to a forum post that explains how to replace the data file with the backup:
Calendar data deleted from Palm Desktop can it be recovered
Feb 10, 2016 | Palm Tungsten T3 Handheld
How do you fix a touch screen that does not respond? I have done a complete reset and still nothing. Thanks.
Have you already performed a clean reset? You might know that it will restore your device to its factory settings, thus deleting everything you have installed, as well as your personal data and settings. So, it is strongly recommended to backup your data beforehand.
Anyway, to perform a clean reset, press and hold the Calendar, Power, and Messaging buttons, and, whilst keeping them pressed, press and hold the reset pin with the stylus pen. When your device restarts, release the buttons and the stylus pen from the reset pin.
Hope it works for you.
Cheers! Carlos
May 12, 2010 | HP iPAQ hx2410 Pocket PC
Contacts and Calendar buttons don't respond
I did a hard reset and the problem was gone (I've lost all the calendar and contacts data but they were restored after making the synchronisation)
Jan 07, 2010 | HP iPAQ rx5915
Starting problem
Hi, Firstly do one thing take a backup of the existing Data. This can be done from Start=>programs=>Xbackup=> choose the desired data i.e. All data or Contacts & appointments. (I forcefully recommend to take Contacts & Appointments) It will take 5 to 10 Min. Remove the Menory Card.After this takes palce, with help of your Stylus press the Reset Button (found at the down end of ur PPC next to the Handsfree Jack.) The Phone will restart with the Factory Settings & will take time. Now after the PPC completely boots check the performance. after scan your memory card with the help of a Personal computer antivirus software & only then restore the data in the similar fashion from the Xbackup utility=>restore.
Note : After restoring the data if the same problem occurs then please again reset the phone & donot Restore your data as it may be corrupt.
Jul 11, 2009 | i-mate JAM Pocket PC
Sync calendar to microsoft exchange server
Update your Versamail version to 3.5.4
Also, make sure that sync calendar and contacts is checked in the settings on your Treo.
Good Luck!
May 21, 2009 | Palm Treo 650 Smartphone
See below
You can do a hard reset to completely restore all the data of your palm.But this will erase all your current settings and restore it to the factory default.Factory default is nothing but it restores the device to the settings when you purchased this one.Reply back to me and i'll tell you how to do a hard reset.
Oct 23, 2008 | Palm Tungsten E Handheld
Sync only goes one way -- from palm to computer
Check the hot sync manager to set the flow of info from desktop to device during the initial restoration of data to your Palm. Afterwards, once you have all your info restored, you'll want the device(s) and desktop calendar to update each other, so make sure your settings in the sync manager reflect that, otherwise you'll continue to have one schedule overwriting the other.
Hope that helps. Let me know how you make out.
Jan 19, 2008 | Palm Z22 Handheld
Its probably conflicting with some app. My palm has gone into infinite reset loops till I did a hard reset. Back up your data, and do a hard reset. (THIS WILL DELETE ALL DATA, AND RESTORE FACTORY SETTINGS)
(hold the power button, and press the reset button, release the reset button (keep holding the power), wait till you see the ORANGE screen (after the loading bar), and release the power. )
Oct 10, 2007 | Palm TX Handheld
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
HTC S710 Smartphone Logo
81 people viewed this question
Top HTC PDAs Experts
Shafky Khan
Lawrence Oravetz
Level 1 Expert
Are you a HTC PDA Expert? Answer questions, earn points and help others
