Question about Refrigerators
KitchenAid model no. KSRS22FGBL03 Fridge is not cooling; freezer side is ok. No cold air being blown into fridge from top or vent in about the middle of the demising wall between freezer and fridge; even when cold air IS being blown into freezer. Compressor seems hot when running and freezer is cooling; even with an external small fan blowing on it to help it out. Normal cooling fan adjacent to compressor is running. Coils are dust free for the most part. Any ideas?
  • 744 Answers
Hi u didnt rate for my chat?
Posted on Jun 02, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | Refrigerators
Freezer is cold, but fridge isn't cooling, cleaned the coils underneath and the port between the freezer and fridge is clear of ice
All of the cooling in refrigerators is normally done in the freezer compartment. A fan circulates cold air from the freezer into the refrigerator compartment to cool it. Most likely this fan has quit working.
Also note that,
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. mostly, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since the unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.Hope this helpout , Good luck
Aug 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
Jun 14, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
Refrigerators Logo
178 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
