Question about Samsung TXN3271HF 32" TV
My SANYO DS32225 32" TV wont turn on.
I fell alseep one night with the tv on. It was storming. I woke up and the tv was off. I tried turing it back on and it wont. I tried new plugins and everything and still nothing. What can this be.
  • 2 more comments
  • Anonymous Dec 10, 2007
    Sanyo DS32225 32" will not turn on. It turned on this morning after a slight delay.
    A fuse? Where is it?
    Sanyo's help line has a recording....someone will answer in 3 minutes.....that was 20 minutew ago. The recording mentions a reset button on the remote which I have probably lost. Is there a reset button on the tv? Can't find one.
    Thanks,
    Mike
  • BETOYGABY Jun 28, 2008
    I DO HAVE A TV 26" SANYO I TRY TO TURN IT ON IT DID BUT 7 SECONDS LATER SHUT OFF AND IT KEEP DOING IT ANY SUGGESTIONS? THANKS
  • c_gonzolez Oct 28, 2008
    i left my tv on for a long time then it turn off by itself and when tryed to turn it back on there was no picture then turned off again by itself
  • mack_donnie May 17, 2009
    my tv will turn on and off but the next day it will not come on at all i was about to put it in the shop after a week but i plugged it in and it worked fine and there it did it again any ideas ?
  • 4,234 Answers
If the set turns on for a while, then shuts down, there is a problem internally that is being detected. The set has a num,ber of error detection circuits that will cause that shutdown to prevent further damage, You can try a "reset" if you like, but I doubt it will help. The easiest way to do this is to unplug the set for at least an hour. More than likely, the set has a number of poor solder connections and possibly defective parts. If you can solder, try resoldering any connections on the board that appear to be grainy or have rings. Update this with your results.
Dan
Posted on Sep 22, 2008
  • 93 Answers
A FUSE
Posted on Oct 26, 2007
    Sergeant:
  • 300 Answers
The Fuse is Located inside the television set but sinse you state that the set powers on but then powers down after a time , that means you do not have a blown fuse , but may have another issue.
The User Manual Link to solve your reset issue.
http://us.sanyo.com/entertainment/televisions/stereo/downloads/DS27425%20DS32225_0201A-(ENG).pdf
Az.
Wont power on and red light isnt on
Main power supply regulator board damaged. Check and replace it.
Dec 08, 2013 | RCA 46" Class LCD 1080p 60Hz HDTV,...
Vizio 55" smart tv e552vle no power or standby light!
Have you tried un plugging the TV for 10 minutes and seeing if that clears the lock up? This is a software issue I'm sure.
Mar 23, 2017 | Vizio L32 32 in. LCD HDTV
I can see the power light but tv wont turn on
Same thing happened to me. I had to have a new board put in. $400. Apparently it's common with Lbs of the era.
May 25, 2013 | LG 32LK330 TV
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
I have a phillips flat screen. I fell asleep watching it one night and woke up and it was off. Ever since then when I try to turn in on it wont come on and there is a whinding noise. I have unplugged the...
This is a CRT tube tv?Yes,than high voltage is dead.The FBT-Flyback transformer is dead.Take the aparts,check the big block of plastic with a red wire with a black cap that hook to the CRT-Tv tube.U hear buzzing sound came from the FBT?Replaced the FBT-the flyback transformer should solved ur tv problems.
Sep 17, 2010 | JVC AV-48WP30 48" Rear Projection...
My 26' sanyo vizon wont turn on and i dont know why.
I have the same tv. Was watching last night when it turned itself off. When I tried turning it back on the switch just made a click noise and nothing happened. After a couple more tries, it didn't even do that.
Jan 26, 2010 | Sanyo DP26746 26 in. LCD Television
RCA D52W19 rear projection tv wont turn on
Try this. Change the channel of your TV to 3, do you see a picture, if not. Unplug your system for the TV. Turn off and unplug the TV. Leave it off for about 10 minutes so it can discharge. Turn back on the TV and see if it re-sets. If this does not work let me know. Give me a detailed report including any brand or models you are asking about. Hope this helps.
JimmyC
Oct 04, 2009 | RCA D52W19 52" Rear Projection Television
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
Feb 24, 2009 | Sanyo DS31590 31" TV
Sanyo 50 inch plamsa just quit!
the power supply of the tv is too sensitive. you need to have a good spike guard for this.
Jan 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Samsung TXN3271HF 32" TV Logo
2,626 people viewed this question
Jerry Greenberg
Jerry Greenberg
