Question about Ryobi Cultivator
No choke on 410r
Vitally, Thanks for the input. I don't have a "choke" on my 410r. There is a yellow toggle that you push down to start and when you depress the accelerator cable it snaps up. Should I leave the accelerator trigger alone until it gets going?
  • 181 Answers
You need to leave the trigger alone until it fires.once it fire you throttle up to release the the choke.the choke is internal.hopes this helps and if you have any other questions let me know..............
Posted on Jun 02, 2009
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
How do i get aux to work on a rca tv
Some TVs don't have an "input" button(mostly older picture-tube types).In most cases,you select"input" by pushing channel down until you are below channel 3.Start at "3",and keep pushing channel down to 2,1,etc.
Sep 07, 2012 | Televison & Video
I have a (i think 20 inch) rca truflat tv and i can't find the channel for video and dvd. the manue didn't help and i don't have the guide"
Press menu on your remote. Press "4" for channel and "4" for video input source. In this menu, you can toggle between s-video and regular video (yellow plug) input. The disadvantage is, if you're like me and you've got a DVD player and and VCR (or maybe a video game system) all hooked up to the same TV, you've got to go through the menu and switch the inputs to watch something else. I'm happy with my digital audio cable; I'll deal with yellow-plug video.
Oct 12, 2011 | RCA TruFlat 27F520T 27" TV
Thanks but my new model 450 doesn't have a blue choke like the others I have owned. This has a sngle lever and goes up to start and down to kill. I push it up, prime it,decompress and pull. It hits...
The start procedure is done on one red lever, as you say prime till the bulb is 3/4 full, push deco vave in, pull the red lever out against the spring and right up, this engages choke and part throttle, pull until it fires once, push red lever down to dissengae choke, then pull again until it starts, flick the throttle trigger to release the part throttle and bring the engine to idle,if all is correct it should start within three to four pulls, if not it needs tuning on the carb screws.
May 19, 2011 | Husqvarna 450 e-series 18" Chain Saw
Hi, I bought a used motorcycle (hero honda splendor+), I dont know anything about choke lever. Please tell me what is the use of it ? Advantages & disadvantages of it? And finally which position...
How to use your choke correctly. The choke is only to be used for starting a cold engine. If it is a lever, usually you pull it up for on , and push it down for off. look for some type off arrow, or up & down. To start your cold engine, turn on fuel tap, give full choke, turn key on and press starter or kick start, it is very important that you do not use the throttle while starting with the choke, just turn the key on, and press the starter with full ckoke, and no throttle. Once the bike fires and starts, turn down the choke a little and find a idle, after a few minits, you can turn off the choke and ride off. The use off the choke is only for starting a cold engine.
Aug 02, 2010 | Hero Honda Splendor Motorcycles
Cylander keeps filling with gas when trying to start
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
OPEN THE CHOKE
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and LISTEN for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 28, 2009 | Garden
Chainsaw won't start
Check for spark
Ignition Coil Test
Smalleng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If spark present put a small amount of mix in the carburetor. Does it at least try to start?
If yes you most likely have a fuel delivery problem.
If no any number of problems. Try your friendly neighborhood chainsaw shop.
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Warm:
Hope this helps
Lou
Oct 04, 2009 | Husqvarna Garden
Will not start
I
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
These flood easily and are very difficult to start once that has occurred.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle - Don’t pull with choke closed.
Hope this helps
Lou
Sep 28, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Jun 02, 2009 | Ryobi Cultivator
Ryobi Cultivator Logo
153 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
