Question about Ingersoll Rand 271 Super Duty 1 Inch Pnuematic Impact Wrench
Air impact tool does not engage but will eventually engage after switching directions.
I have a standard duty 1/2" Craftsman pnuematic impact tool. problem is it seems to not engage in gear, however if the direction is reversed and then returned to original it will usually catch and "ratchet" as normal. Can I do repair on this tool? If so, are special tools required and where can i purchase parts?
  • 256 Answers
Although I do not have a Craftsman, I have taken severl othe brands apart. They all seem to be much the same. You do not need specialized tool. You just have to be mechanically savey. I think the grease has thickened up too much so taking it apart and cleaning it should do the trick. Start at the working end end and separate the front end. Work on a clean bench where little items (screws, ball bearings etc) won't roll off and get lost. When the two parts are separated, you should see the hammer mechanizm and a lot of grease. remove and clean everything that you can. Re-lube the mechanizm with a light lube grease and re-assemble. Turn the socket drive by hand to make sure everything is free, then apply a liberal application of air tool oil to the air port of the gun and attach an air line and give it a try . Put a load on the socket to check for impact functioning properly. I hope this helps
Posted on Jun 02, 2009
How i can get a owner manual on a impact gun
The manual is available here: http://www.chicagopneumatic.pl/files/file/pliki_serwis/pliki_serwis_narzedzia/RP_9545.pdf . This is a global edition of the manual with only a few pages of information in each language. The important pages pages 1 and 12-13, if English is your primary language.
I hope this helps.
Jun 18, 2014 | Chicago Pneumatic Chicago Pnuematic 825T...
How do you oil a Craftsman Air Impact Wrench Model No. 875191182?
Just put 3-5 drops of air tool oil down the air inlet coupler and then run the gun for 5 seconds. Do this everyday that you run the gun for best results.
Feb 25, 2011 | Craftsman 1/2" Impact Wrench
Wont work in remove direction just blows air
fill it wit oil hold in triger and flick between forard and reverse should free up the vains inside
Jun 29, 2010 | Craftsman 1/2" Impact Wrench
What sockets fit
Any sockets will fit the ratchet, 3/8 drive, the impact drive is 1/2 drive, and they make hardened sockets for it. And I can't really make out the last tool there in the kit. The impact tool will take normal sockets for reg duty use but not for wheel lugs and such, they will crack, but if you buy Craftsman, they will replace it. I have only cracked one in thirty years. But I also have the hardened set of sockets. Hope this helps.
Jun 25, 2010 | Craftsman Mechanics Air Tool Kit Impact...
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
Craftsman 1/2 inch impact air driver leaks air
put a bunch of hydraulic oil in it and this will lubricate the seals inside to form a more uniformed seal it will stop leaking air.
Sep 03, 2009 | Air Tools & Compressors
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Aug 27, 2008 | Ingersoll Rand 271 Super Duty 1 Inch...
Ingersoll Rand 271 Super Duty 1 Inch Pnuematic Impact Wrench Logo
291 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
