Question about Sony Handycam DCR-TR7000 Digital Camcorder
How to fix Sony DCR TR7000 Firewire port
I've been able to connect my Sony DCR TR7000 to my PC for a while, but it suddently stops working. My PC Firewire port is fine (because I have another Sony MiniDV camcorder with Firewire and it is able to connect to my PC fine); so something's definitely wrong with my Sony DCR TR7000 Firewire port. Any idea of how I can fix this?
  • vanhuy Jun 02, 2009
    Thanks for the quick response. Can you tell me where I can get the new input board?
  • 643 Answers
If you can open camera make sure the ribbon cable from port is seated all the way. if not replace input board.
Posted on Jun 02, 2009
  • Mando Mojica
    Mando Mojica Jun 02, 2009
    local sony service center. not sure of part #
  • Mando Mojica
    Mando Mojica Jun 03, 2009
    here is sony part # for input board and ribbon cable.
    A-7073-920-A that is direct replacement . Hope that helps.
Hi, I 've got a Handycam Digital 8 (DCR-TRV270E) and Windows Vista Home Basic and have lost the software for my camera and my PC doesn't recognize the device when it's imported to usb port. How can I...
Are you connecting using USB or Firewire? Unfortunately there are no USB Windows Vista drivers for your particular camcorder but using a Firewire(i.link) Cable should work. For further reference here is the support site for your camera. Camcorder Support Site
Mar 05, 2011 | Sony DCR-TRV270E Digital-8 Digital...
I have a SONY DCR-TRV950 and can not download video via the USB cable. Any thoughts?
Hi there, I've just posted my own answer to the same problem, my own problem, elsehwere on here. My solution was to insert a Firewire card into my PC and use that port. I checked with Sony and they said my original USB cable and port was not appropriate with Windows 7 64 bit, that a Firewire port was best. When such a Rirewore port is used then the correct driver automaticllly become available to you, if you have Windows 7 that is. I probably wrote the answer much better first time around on my other posting.......
Dec 18, 2010 | Sony Handycam DCR-TRV950 Mini DV Digital...
DCR-HC52 fire wire port doesn't work. Have tried on several computer, none of them even see the camera. Best Buy tried using a different cable same results
This happens only mostly if you connect camera on Firewire AFTER you been PC okay, so plug your camera in the Firewire sockets then put your PC on, then the PC will open the firewire port up for use and set up a user port adrs for the port.
Jun 05, 2010 | Sony DCR-HC52 Mini DV Camcorder
How transfear data ( tap record )from camera to computer
You need a "firewire" card in your desktop or laptop. The iWire cable then connects to that and to the camera. If you are using XP on your pc, you most likely have MS Movie Maker which should work fine for both transfer and editing your movie on your pc.
May 15, 2009 | Sony Handycam DCR-TR7000 Digital Camcorder
I can't get Firewire to work on my Sony DCR-PC101e.
No special soffware or driver is needed provided that your PC has a firewire port ...
Dec 15, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
DCR-HC32E
You need a FireWire cable and a computer with FireWire port. I have same camara - it comes with a base unit into which you have to plug in the camara. From that base unit connect the firewire cable (4pin) and take that to your computer which may have a firewire port (either 6pin or 4 pin) - depending on what kind of firewire port you have on the computer, you have to get appropriate cable ... it is my understanding that the camara doesn't come with this cable. I purchased a firewire cable with 4 pin connecter on both ends to connect to my IBM laptop with Vista on it. It works great after all this setups. It does not work with a USB cable for some reason.
Jul 13, 2008 | Sony DCR-HC32E DV Digital Camcorder
Connecting Sony Handycam DCR-HC14E to iMac
There is a great manual here:
http://www.sony.co.uk/support/ShowExternalPage.action?product=DCR-HC14E&supportProductModelName=DCR-HC14E&linkType=manual&isRegistered=false&site=odw_en_GB&pageType=manualPopup&sectiontype=Support&externalUrl=http%3A%2F%2Fpdf.crse.com%2Fmanuals%2F3089850112.pdf&externalLinkType=manual
And in short the I.link is a 1394 port or firewire port
You should be good to go
May 02, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Firewire Port not working
HAVE YOU HAD THE CAMCORDER ON THE MAINS ADAPTOR WHEN IT WAS CONNECTED TO THE FIREWIRE AS IT HAS TO BE TO POWER THE FIREWIRE PORT!
Nov 08, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony Handycam DCR-TR7000 Digital Camcorder Logo
509 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
