The broplem is the quantity of water is not enough for washing
SOURCE: User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
SOURCE: washing machine inlet/drain problem
You may have a simple problem known as "siphoning". Have you checked your installation/ In particular, the drain hose? the following link explains how to check and correct a siphoning problem with a washer:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Usually when a washer drains as it tries to fill, its a drainage problem of some type. You may have a simple problem that is easily remedied. You may not require anything, but pulling the drain hose up out of the standpipe and repositioning it to ensure there is a proper air gap for drainage. I hope this helps you.
Im assuming that the water is not releasing all the powder and your spin cycle is not completing its cycle....
SOURCE: MY KELVINATOR KL15TL WASHING MACHINE DOES NOT
I can think of three possible causes. The first is the timer not advancing to the wash cycle. Try manually advancing the timer and see if it will start. The second possibility is the drive motor or drive belt. Open the access panel to see if the belt is intact, then see if the motor starts when you manually advance the timer to wash. The third possibility is the lid switch. You can usually get to it by inserting a putty knife in the two from corners to pop the spring clips open, and the top flips back.
SOURCE: i need the user manual for kelvinator km45w please
I've lost mine. Please , can you send the manual at [email protected]? Million thanks.
