Question about Electrolux ICON 30 in. Double Wall Oven
Turning off oven.
My oven doesn't seem to cool down and turn off fast enought. Last night I baked a casserole for an hour, I hit cancel to turn it off.  The touch screen was dark, so it looked like it was off, yet for 2 hours... no exaggeration... 2 hours it blew hot air and the burners were still hot. It finally turnes itself off, but it always takes about 2-3 hours. I noticed the fan isn't on in the back when I turn it off... My question is, does the fan only come on when you are cooking with the convection features, or should it come on during oven cool down. It doesn't come on, so that may be my problem. I just don't know. I can't find my instructions. Am I doing something wrong?
"...but uses a bunch of air conditioning in the summer"
Well, it wouldn't actually use *less* air conditioning if it cooled down slower by itself. The total amount of heat released from the oven (and hence pumped out from the house by the air conditioning) would be the same, but over a longer time.
Posted on Mar 21, 2008
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Posted on Feb 27, 2008
Whirlpool super capacity 465
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite high...it keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Nov 30, 2013 | Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    Oven takes forever to preheat
    check to see if both broil and bake elements/gas works
    May 25, 2010 | Maytag CWG3100A Gas Single Oven
    Accidently started clean, food inside,hit cancel,can't open
    you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
    May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven - Failed baked goods, takes too long on other things
    most ovens have what is called tempture sensor,its job is to read the tempture within your oven if this sensor is faulty then it sends the wrong signal to your display,you talk about a thermometer showing a different temp please do not put this thermometer in your oven some of these contain mercury and could explode in your oven.I would advise you to call a electrication and get him to test your tempture sensor.sorry i cant help you any better.adrian
    Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Dacor Oven Won;t Heat
    power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
    Jul 19, 2007 | Dacor ECS130 Epicure Electric Single Oven
    Electrolux ICON 30 in. Double Wall Oven Logo
    317 people viewed this question
    Top Electrolux Ovens Experts
    Mack Baxter
    John Tripp
    John Tripp
    Are you an Electrolux Oven Expert? Answer questions, earn points and help others
