Question about Wharfedale Diamond 8.4 Main / Stereo Speaker
Drivers swap hi, i need to swap bass drivers in my wharfedale diamond 8.4 and i'm not sure how. i took out the screws around the driver but the part i thought is just a frame is still sitting there firmly. i don't wanna destroy it. is there anybody who've got experience with them? cheers
  • radim_vavrec Jun 02, 2009
    i sort it out, need to release all screw and fight with glue.
    Problem Solver:
  • 19 Answers
With some speaker cabinets, the manufacturer will put some form of adhesive to seal the speaker to the cabinet so there's no space between them. I've often found that all it takes is to use a thin bladed flat screwdriver and insert it gently between the speaker frame and the cabinet to break the seal and free the speaker. You may need to tap the screwdriver in a bit, then twist it, but if you find you must use a lot of force, this may not be the solution for you. Please rate my answer, thanks.
Posted on Jun 18, 2009
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
My child has damaged the cone on the woofers of my Wharfedale Diamond 9.1 speakers. Can I replace these?
Of course you can replace them, if you can find the woofers at your area. Unscrew the 6 screws that are securing the woofer (I suggest to unscrew the top-middle screw at the end of all in order to keep the woofer in it's place). Pull the woofer out and disconnect the 2 wires, paying attention which collor is at which side of the woofer. Replace with the new one. Connect the 2 wires. Screw it up (first of all the top-middle screw) Never tighten to the end each screw, tight one after the other, little by little.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 29, 2010 | Wharfedale Diamond 9.4 Main / Stereo...
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
I have a pair of Wharfedale Diamond 7.2 Anniversary speakers and one of them has a blown woofer - how do I get into the speaker - there are no apparent screws to access into the cabinet? Help Also,...
On the back of the speaker are six deep holes that screws the back panel to front baffle.There are six sponge plugs normally.You have to dig these out with
a long standard screwdriver or however you can get them out to expose the 6 Phillips head screws below them.Remove the 6 Phillips head screws and the whole speaker comes apart,leaving just the box.Good luck.
Jan 27, 2009 | Wharfedale Diamond Anniversary Main /...
Wharfedale drivers
i have a
Wharfedale FM6709i really need a driver for this product can you tell me where to go or the download site needed.
Mar 07, 2008 | Audio Players & Recorders
Problem with Diamond 8.4
No - sounds like the speaker/ cross over is faulty - I assume there are only one set of connections on the back - on some speakers you have 4 connections for dual wiring - and you usually bridge those out Play a piece of music with some drumming in it and you should see the midrange move a lot Just to make sure there is not a problme with the Amp - swap the speakers around - so you have a left speaker and a right speaker connected physically move the left speaker over to the rightside and connect to right side cables - and the right speaker to the left side and connect to left cables Now if the problem goes over to the other side - its the speaker thats fault if it stays on the sam side - its the amp
Apr 12, 2007 | Wharfedale Diamond 8.4 Main / Stereo...
Wharfedale Diamond 8.4 Main / Stereo Speaker Logo
131 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
