Question about Bowflex Xtreme SE
Rod won't return to upright position
I just recently bought a bowflex xtreme 2 se and when I try to use it, there is slack on one side and the rod will not return to its original position. Its almost like the cable is too long.
I know with my bow blex the cable was always twisting, I had to take it off and turn it around
Posted on Jun 02, 2009
First, make sure you have routed cables exactly as shown in assembly manual. After that, be very sure that all sliding pulleys are symmetrically positioned; this means looking at the bowflex head on down the middle, all pulleys on the left are in "mirror image" positions on the right. I know that as I get used to my Xtreme, I continually make the mistake of not postitioning the pulleys properly, and then wonder why one set of cables seems longer than the other. Hope this helps you or someone else looking in.
Posted on Sep 04, 2009
I just threaded my bowflex cables and rods hit the cross bar - i have an extreme 2
I had the same problem with my Xtreme and here's what worked for me, and I'm assuming the Xtreme2 is put together pretty much the same way. Remove the rod box from the lower lat tower frame by removing the 3 screws that hold it in. Much easier if you can tip the Bowflex on it's side, or at least have someone hold it at an angle while you're removing the screws. Once you have the rod box off, you'll see that there is a screw holding each rod into the box. Remove that screw and pull the rod out about an inch or so. Rotate the rod 180 degrees and reinsert it. There's a slot in the end of the rod that engages a key, so make sure it's engaged, you shouldn't be able to rotate the rod if it is. Then reinstall the screw. Repeat for whatever other rods are hitting the cross bar and then reinstall the rod box. Worked like a champ for me. Make sure you unhook the rods from the cables when you're done with your workout, that'll really shorten the life of them if you leave them bent all the time.
Sep 04, 2011 | Bowflex Xtreme SE
I just got a bowflex extreme 2 from someone used. It is from 2006. There doesn't seem to be enough resistance? How can I make more tension in the rods? Seems too loose?
The nice thing about the Xtreme 2 is the fact that you do not need to change cables for different exercises, but it does mean numerous cable position adjustments depending on the exercise you are doing.
To alleviate the slack problem in the cables you can either have the cables that run under the seat remain attached to the leg extension attachment or move the sliders attached to those cables as far forward as possible thereby pulling the cables as far out as they can go. This will both increase the resistance provided by the rods and keep the floating pulleys from hitting the lat pulley housing.
Jan 24, 2011 | Bowflex Xtreme 2 Se Gym
I have bowflex extreme 2. Power rods hit the pulley arms when bent.
I called Bowflex and they said there is a Lower Lat Tower Upgrade (Part 001-9704) that fixes the problem for $106.10. Seems like a design defect to me, not an upgrade. Regardless, I have not purchased the part yet to see if it fixes the problem.
Nov 30, 2009 | Bowflex Xtreme 2 Se Gym
Handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Jun 17, 2009 | Dyson DC25 All Floors Bagless Upright...
V-rod gear shifter won''t click back up
sounds as though your gear lever return spring has broken and will need replaceing
Dec 27, 2008 | 2004 Harley Davidson VRSCB V-Rod
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Oct 21, 2008 | Bowflex Revolution Home Gym
Bowflex Xtreme SE Logo
1,384 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
