Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
Why is my window unit just blowing warm air? the filter is clean,
There is no drain hole to clean out and I can't get the thermostat below 66
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Shut the lever to outside resiculation air.
Put the fan on slow,
Clean the filter and the temp probe in front of it
Vitally
Posted on Jun 02, 2009
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
How to change my engine coolant in a 1992 ford ranger-v6 3.0 engine, with what kind of coolant and how much of it
Hello again Vicki, you can read my first post to you on type. Now for where and how. Put suitable container under radiator drain valve. Start to drain old antifreeze, you can also loosen radiator cap for faster drain, but make sure antifreeze doesn't start to spill all over your driveway or garage floor. When radiator and engine are mostly drained, I would recommend to change the thermostat. Follow the top radiator hose down to the engine. This is where you'll find the thermostat. Remove the attaching bolts and remove thermostat.If you wish to flush your engine,you can put water down the thermostat hole as well as the radiator cap hole, or you can do a fancy flush. Shut drain below, reinstall thermostat housing without thermostat, fill radiator with fancy flush cleaning solution and water replace radiator cap ,run for time stated on can of flush. Now you go back to where I began and start the draining again. Dispose off antifreeze correctly it is dangerous to animals if they ingest. Close drain,and fill engine with antifreeze thru thermostat housing, when almost to top install new thermostat and gasket. fill radiator almost to top, start engine, open inside heater and let engine warm to operating temperature. At this time the antifreeze level will drop, because thermostat will open, and you can fill some more .This should eliminate any possible air bubbles. Fill your coolant tank. I would like to know how you make out. GOOD LUCK.
Oct 11, 2011 | 1992 Ford Ranger
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
Hi, my air conditioner works fine but if I leave it on to long it will start blowing out warm air. Then when I turn it off, it sounds like its still on. And I have to wait a whole day before it blows cool...
Sounds like the unit is icing up.
Window air conditioners are not usually of sufficient capacity to keep a room much below 74°F. If not allowed to cycle off occasionally during the day, the evaporator (cold radiator) will ice-over and prevent air from passing through it.
The way most are constructed, the water is designed to drain to the bottom near the compressor. The heat of the compressor and air provided by the condenser fan motor are intended to evaporator the condensate.
Try using a higher setting on the unit and see if that helps. It needs to be able to shut-down once in a while. If you have the option, set the fan switch to 'on' instead of 'auto'. This keeps the inside fan motor blowing all the time, with the compressor cycling as needed. The moving air will make the conditioned space more comfortable with a higher temperature setting.
Jun 28, 2011 | Heating & Cooling
I need to replace the thermostat it is sticking
DRAIN COOLANT LEVEL DOWN BELOW THERMOSTAT.PLACE DRAIN PAN UNDER VECHICLE TO CATCH ANTIFREEZE.WHEN DONE PUT ANTIFREEZE SAFE PLACE FROM KIDS AND ANIMALS.WHEN DONE DRAINING SOME ANTIFREEZE.FOLLOW RADIATOR HOSE TO TOP OF INTAKE TO THERMOSTAT HOUSING. LOOSEN HOSE CLAMP REMOVE RADIATOR HOSE FROM THERMOSTAT HOUSING.THEN LOOSEN HOUSING BOLTS.REMOVE THERMOSTAT HOUSING AND THERMOSTAT.CLEAN BOTH THE THERMOSTAT HOUSING SURFACE AND INTAKE SURFACE YOU CAN USE ACETATE OR BRAKE CLEANER AND SCOTCH BRITES ROLL OF CLEAN PAPER TOWEL. AFTER CLEANING HOUSING AND INTAKE SURFACE MAKE SURFACE CLEAN SMOOTH FROM THE DEBRIS WHEN DONE. TAKE THERMOSTAT PUT GASKET SEALER ON BOTH SIDES OF GASKET PUT GASKET TO THERMOSTAT HOUSING MAKE SURE GASKET AND THERMOSTAT HOUSING HOLES ALIGN CORRECTLY.NOW PLACE NEW THERMOSTAT IN PLACE IN THE INTAKE.MAKE SURE THERMOSTAT SPRING END GOES TOWARD ENGINE FACING DOWN.THEN INSTALL THERMOSTAT HOUSING WITH GASKET TO THE INTAKE.TORQUE THERMOSTAT HOUSING BOLTS TO 20 FT LBS.WAIT 1 HOUR BEFORE POURING ANTIFREEZE BACK IN THE COOLANT SYSTEM GIVE THERMOSTAT GASKET SEALER LITTLE TIME TO CURE.SO YOU WONT HAVE COOLANT LEAKS.NOW IF THERMOSTAT HAS THE LARGE O- RING ON IT YOU DONT HAVE A THERMOSTAT HOUSING GASKET THE THERMOSTAT O- RING IS THE SEAL THAT HOLDS COOLANT INSTEAD OF GASKET.WHEN THERMOSTAT AND HOUSING IN PLACE.INSTALL RADIATOR HOSE TO THERMOSTAT HOUSING TIGHTEN HOSE CLAMP.THEN FILL RADIATOR BACK UP WITH THE COOLANT YOU DRAIN OUT.START VECHICLE UP. THEN CHECK FOR LEAKS.
Nov 03, 2010 | 1992 Buick LeSabre
Thermostat replacement 1994 nisan sentra 1.6 eng how to remove and replave
JUST DRAIN COOLANT LEVEL BELOW THE THERMOSTAT. CATCH COOLANT IN A DRAIN PAN UNDER RADIATOR.THEN REMOVE RADIATOR HOSE FROM THERMOSTAT HOUSING ON THE CYLINDER BLOCK.THEN REMOVE THERMOSTAT HOUSING AND THERMOSTAT.CLEAN THERMOSTAT HOUSING SURFACE AND THERMOSTAT HOUSING SEALING SURFACE ON CYLINDER HEAD.INSTALL NEW THERMOSTAT IN PLACE,MAKE SURE THERMOSTAT AIR BLEED HOLE FACING LEFT SIDE UPWARD ON THE ENGINE.SOME THERMOSTAT HAS TOP STAMPED ON IT.MEANING MUST BE FACING UP.WHEN THERMOSTAT IN PLACE.TAKE NEW THERMOSTAT GASKET.PUT SEALER ON BOTH SIDES OF GASKET.THEN.PUT GASKET ON THERMOSTAT HOUSING.THEN PUT HOUSING IN PLACE TORQUE HOUSING BOLTS 16 - 20 FT LBS.WAIT 1 HOUR UNTIL GASKET SEALER CURE.THEN FILL UP COOLANT SYSTEM.BLEED COOLANT SYSTEM AND CHECK FOR LEAKS.
Sep 17, 2010 | 1994 Nissan Sentra 4-Door
Replacing the thermostate
drain out coolant in a drain until below thermostat level follow radiator hose to engine cylinder block to thermostat housing.remove thermostat housing than remove thermostat.replace with a new o-ring on thermostat before installing new thermostat.make sure thermostat housing surface and engine block surface clean.before installing new thermostat.
Aug 16, 2010 | 1997 Isuzu Trooper
Where can i find the thermostat on 1986 gmc jimmy
Follow the upper radiator hose to the outlet elbow (the waterneck!) and it is located under it:
Removal & Installation
  1. Drain the radiator until the coolant level is below the thermostat level (below the level of the intake manifold).
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the water outlet elbow assembly from the engine. Remove the thermostat from inside the elbow.
  2. Install new thermostat in the reverse order of removal, making sure the spring side is inserted into the elbow. Clean the gasket surfaces on the water outlet elbow and the intake manifold. Use a new gasket when installing the elbow to the manifold. On later models the thermostat housing may have been sealed with RTV sealant. If so, place a 1/8 inch bead of RTV sealer all around the thermostat housing sealing surface on the intake manifold and install the housing while it is still wet. Refill the radiator to approximately 21/2 inch below the filler neck.
If the thermostat is equipped with a pin hole, be sure to install pin side facing upwards.
Nov 19, 2009 | 1986 GMC Jimmy
Does the product a/c have a drain hole?
Air conditioners of your type have tiny passages that allow the water (if clean) to go to the back of the unit where a splash ring on the fan blade whips the water onto the hot condenser coil, eliminating the condensate outdoors and subcooling the refigerant in the condenser in doing so.
If you have water inside and its level or slight tilt back , then you need to clean it up or forget it!
Aug 25, 2009 | Fedders A6U10W7A Thru-Wall/Window Air...
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
949 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
