My lcd tv picture has vertical ghost lines equaly spaced apart and each line has the identical geometric shaped pattern, anyone have any ideas. regards richard
  • BUZZ20 Jun 02, 2009
    my SEANIX LCD TV HAS VERTICAL EQUALY SPACED GEOMETRIC PATTERNS FROM TOP TO BOTTOM OF SCREEN. THEY ARE CONSISTANT WETHER WATCHING TV, DVD OR PS3.
    RICHARD
    the lines are sharp and stationary, there are fifteen on the 28 inches of the screen. starting at the top they are 1 inch wide for the first third narrowing from the right hand to half an inch for the second third the returng to 1 inch wide for the last third. there are three rectangular shapes clipped in the first third and two rectangular shapes clipped in the last third, little bit like a train ticket punch. some but not all of the pixels appear to flicker.
                           regards
                           Richard
  • 5,807 Answers
It is inside your controller board, it would be very tricky to repair cause you will be unplugging connectors , have that board reheat , re soldered if problem still persist you have to replaced the entire controller board,i would rather suggest have an experienced qualified authorize technician to handle this, if still in warranty have them informed the trouble your having they will send one for you, or inform where you bought the unit of the problem they might have suggestions for you.and if warranty is already expired be ready to look for the controller board replacement in case repairing the board wont help. if you want to do it for yourself ready your camera, multimeter and a lot of patience, record or have a picture of original connections so that you can bring it back later from which it is being connected.a notepad where you can record what are you doing, and the parts that will be replaced it would be like in intensive care unit. hope this help, thanks for using fixya!
Posted on Jun 02, 2009
  • Rommel Cana
    Rommel Cana Oct 01, 2009
    hi,
    i just hope your TV is OK now, if still isn't please indicate the model number so i can help you more.
  • 3,037 Answers
Hi Richard. You need to describe these lines better. Are they moving or stationary? Are they very fine lines with sharp edges or are they more like bands with soft edges? How many lines do you see, and how wide are they (compared to the screen width)?
Fine lines that are stationary: defect in the electronics causing a vertical row of pixels to be dead or stuck. Can only be fixed by replacing major parts.
Broad lines with soft edges that move: could be electrical "hum" interference. Make sure you are using a grounded (3-pin) power plug, and that the outlet is properly wired. (Take the TV to a another location and see if the problem goes away).
Make sure you don't have fluorescent light fixtures nearby--they can interfere with the picture if the bulbs or ballast is defective. Also try with or without a surge protector, depending on what you have hooked up now and see if that makes a difference. Otherwise you might have some dry joints and require a professional to check it and fix it. Let me know if you have further questions.
Benjamin
  • 136 Answers
You should check out the RCA cables the red yellow and white ones connected to your tv from your cable box, or the Blue Green and Red component cables. If those are fine it might be just static due to bad connection from satellites...
Samsung LCD TV has pattern of short horizontal lines on screen.
The TV may be picking up stray radiation from another piece of equipment, try disconnecting and unplugging all other digi/cable/dvdplayers/phones etc. to isolate the offending article
Jan 24, 2018 | Samsung Televison & Video
LG TV 42LV5500 with vertical lines
T con Board or the LCD panel of the TV is faulty. You have to replace the Tcon Board to confirm where it is T con Or LCD panel.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 15, 2016 | LG 42LV5500 42 in. LCD TV
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
How do I fix vertical lines and no picture.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Dec 08, 2006 | Sony Grand WEGA KF42WE610 42" Rear...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
