Question about Dryers
Doesn't move hot air to the outside
Kenmore dryer 70 series-MK0735122 it seems not to be moving air to the outside. It's heating up just fine (new element) but the whole unit is heating up almost to hot to touch and the clothes are kind of getting dry but really just staying damp.
  • frebfam Jun 02, 2009
    Thank you that was it exactly somehow a sock fell into the lint trap and with a little cleaning all is well.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Clear obstruction to hose outlet.
Vitally
Posted on Jun 02, 2009
Kenmore series 80
Yes a wire may have come loos or the element has move slightly. although a screw is supposed to hold the heating element. it is possible that it slipped out first.
Jul 27, 2014 | Kenmore Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Kenmore 80 series not heating. vent is good and clean and air is moving forcefully outside.
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Nov 26, 2010 | Kenmore Dryers
Kenmore Dryer 70 series. Recently moved. Clothes take 3 cycles to dry when vented to wall vent. Woreks fine when vented to room.
Your wall vent is restricting your air flow somehow. Many times they get plugged with lint. When this happens it activates a thermal safety switch in the dryer and doesn't let it heat to the proper level.
Jul 03, 2010 | Dryers
My kenmore series 80 model # 110.74852400, takes forever to dry. the flame comes on, but doesn't seem to stay on for long. please help. thank you
my kenmore dryer ignites runs for awhile then wont reheat. let it sit for a few minutes and it will heat again for awhile
Apr 20, 2010 | Kenmore 72802 Gas Dryer
Won't dry clothes
Try running the dryer with the vent pipe unplugged. There should be a lot of hot air coming out, if not the insides need to be cleaned. If it really moves air, and dries a load ok unhooked, your vent is clogged. Clean it if you can. If you can't, look into a lint trap that will work for your situation, some have a water trap, some are good filters, etc. If the air is not hot, some of the electric element may be bad. If it's gas, it could need a tune up and cleaning inside.
Apr 24, 2009 | Kenmore Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Aug 24, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Dryers Logo
98 people viewed this question
Top Dryers Experts
